I have 2 Synology NAS at work using https://www.synology.com/en-global/..._availability_configuration_with_Synology_NAS so I was wondering if freeNAS can get close to that.
Synology does it this way: both NAS are connected via direct connection and they both monitor the others heartbeat. Once one fails users automatically access the other one and data is automatically synced between both. The "cluster" is accessed by users via one IP which basically points to the master NAS, if that one fails the IP automatically points to the slave one. *described in my own words, more or less accurate*
I'm not looking for the exact same complexity but is it somehow possible to keep 2 FreeNAS completely in sync automatically? and I mean completely (config and data) so if one fails I can replace it with the other one manually at least?
