About two weeks ago I installed FreeNAS on an old computer. It was pretty easy and fun to set up with help from this forum! So I decided to make a proper build to store my valuable photos and documents on. It will need to run Plex and stream my photos to my chromecast smoothly. These photos are mostly JPG, sometimes RAW. That means either ±15mb or ±25mb. I did my research and picked some parts I think will do a good job for my needs.
Motherboard: Fujitsu D3417-B2
Memory: Crucial 2 x 8GB DDR4 ECC - CT2K8G4WFS824A
Processor: Intel Xeon E3 1220 V5
Power supply: Be quiet! Pure Power 10 400W CM
Drives: 3 x 4TB - (Seagate Ironwolf or WD Red?)
Case: Cooler Master N400
I am not sure about the processor. Can it handle everything, is it overkill, or is there a better option? I am also not sure about the drives, and don't know yet what RAID configuration I will use. The rest of the components, is that allright? I don't want to spend hundreds of euros more.
Thank you!
Thank you!
