Help with state: UNAVAIL
NumLock
Hi I have freenas with 6 3B raidz2 3 disk fail only 3 are working properly here is the output when I try to import the pool:
root@Home2:~ # zpool import
pool: Home
state: UNAVAIL
status: The pool was last accessed by another system.
action: The pool cannot be imported due to damaged devices or data.
see: http://illumos.org/msg/ZFS-8000-EY
Home UNAVAIL insufficient replicas
raidz2-0 UNAVAIL insufficient replicas
2227781247629305773 UNAVAIL cannot open
11438768472496969598 OFFLINE
14103484239164733802 UNAVAIL cannot open
1472901793690406249 UNAVAIL cannot open
gptid/de238569-b4a5-11e4-ae06-0015171c9eec ONLINE
gptid/e6792e14-b4a3-11e4-ae06-0015171c9eec ONLINE
I try the fallowing:
1) I check the cables PSU etc
2) Install fresh NAS OS on new motherboard and try to import same result.
SweetAndLow
Sweet'NASty
Output of camcontrol devlist? Smart output for all disks? Looks like you just have some failed disks.
NumLock
root@HOME:~ # camcontrol devlist
<PATRIOT MEMORY 32GB SSD 02.10104> at scbus1 target 0 lun 0 (pass0,ada0)
<ST3000DM001-1CH166 CC43> at scbus3 target 0 lun 0 (pass1,ada1)
<ST3000DM001-1ER166 CC25> at scbus4 target 0 lun 0 (pass2,ada2)
<ST3000DM001-1CH166 CC43> at scbus5 target 0 lun 0 (pass3,ada3)
<ST3000DM001-9YN166 CC9E> at scbus6 target 0 lun 0 (pass4,ada4)
<ST3000DM001-9YN166 CC9E> at scbus8 target 0 lun 0 (pass5,ada5)
SweetAndLow
Sweet'NASty
Currently you only have 5 drives attached. What version of freenas do you have and what are your full hardware specs?
NumLock
Upgraded to v11
FreeNAS-11.0-RELEASE (a2dc21583)
Platform AMD FX(tm)-4100 Quad-Core Processor
Memory 7897MB
Boot from SSD 32GB (This is apart of other disk only for OS)
ASUS Motherboard
SweetAndLow
Sweet'NASty
Upgraded to v11
Memory 7897MB
ASUS Motherboard
Well from the information you have provided I think you just had your drives fail. To prevent this you need to run smart tests and have email alerts setup.
This system was neglected and that is why it's dead.
Do you have smart data output like I asked for?
smartctl -a /dev/ada1 for example? Also do 2-5.
If those three disks have truly failed, pack it up, you're done. RAIDZ2 will protect against failure of two disks, but not three.
NumLock
ada1
ada2
ada3
ada4 New Disk Replace bad disk dead
ada5 New Disk Replace bad disk dead
  • ada-list.txt
NumLock
One of bad disk is detect on boot up but say S.M.A.R.T. fail but I was unable to see on freenas list disk.
NumLock
If I clone one of the disk are good to new drive the pool will be available again?
If not is possible to recover the data from the good drive?
SweetAndLow
Sweet'NASty
This! Your pool and data are gone. You can't neglect your pool and let that many disks fail. When one drive even hints that something is wrong you need to replace it then and there.
NumLock
I know but after upgrade for some reason many disk fail so with 3 disk I cant resurrect the pool?
SweetAndLow
Sweet'NASty
No? Why do you even ask? You had raidz2 which can only do 2 drive failures.
The upgrade had nothing to do with your disk failures. You just never noticed until you logged in to mess with things.
Stux
And Seagate 3TB drives are prone to failure.
Your jnmy hope is to get one of the 3 dead drives to come back.
Time to restore from your backup.
NumLock
Totally agree Seagate suks I will never buy Segate again. I will try again to put one bad disk hope comes online to backup data. If I clone one of the good disk to new drive can the pool will be online again?
Stux
