Pool state UNAVAIL
aquades
HI ,
Need help , my Freenas suddenly cannon access the file share, when checking, is this can recover / fixing ?
FreeNAS-11.1-U7
root@*****:~ # zpool import
   pool: DGK-SHARE
  state: UNAVAIL
 status: The pool was last accessed by another system.
 action: The pool cannot be imported due to damaged devices or data.
   see: http://illumos.org/msg/ZFS-8000-EY
        DGK-SHARE                                       UNAVAIL  insufficient re           plicas
          raidz1-0                                      FAULTED  corrupted data
            6897442800342792544                         FAULTED  corrupted data
            gptid/f7509ac2-e6a3-11e7-8af2-984be172e370  ONLINE
            13264498795292541195                        UNAVAIL  cannot open
            gptid/f99eeee1-e6a3-11e7-8af2-984be172e370  ONLINE
            gptid/fac6d71d-e6a3-11e7-8af2-984be172e370  ONLINE
Chris Moore
Your post indicates that one of your disks is faulted but still present while another disk is unavailable. Have you removed a drive from your system?
A RAIDz1 pool, what you have, can only tolerate the loss of one drive where you have two that are not functional.
If you can't get one of those drives back to an available state, you have lost your storage pool and it is this type of fault that makes RAIDz2 the preference because it allows for the loss of two drives without data loss.
