Easygoer
 - Mar 11, 2014
I am getting the following kernel log message from the security run output. I am certainly not an expert in FreeNAS and have no idea what it means.
I can only "speculate" that this has something to do with the HDD labelled ada0. Here are the details:
(ada0:ahcich0:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 10 00 63 40 8a 00 00 00 00 00
(ada0:ahcich0:0:0:0): CAM status: ATA Status Error
(ada0:ahcich0:0:0:0): ATA status: 41 (DRDY ERR), error: 10 (IDNF )
(ada0:ahcich0:0:0:0): RES: 41 10 10 00 63 40 8a 00 00 00 00
(ada0:ahcich0:0:0:0): Retrying command
(ada0:ahcich0:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 e8 df 96 40 8a 00 00 01 00 00
(ada0:ahcich0:0:0:0): RES: 41 10 e8 df 96 40 8a 00 00 00 00
(ada0:ahcich0:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 50 e3 97 40 8a 00 00 00 00 00
(ada0:ahcich0:0:0:0): RES: 41 10 50 e3 97 40 8a 00 00 00 00
(ada0:ahcich0:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 d0 f9 97 40 8a 00 00 01 00 00
(ada0:ahcich0:0:0:0): RES: 41 10 d0 f9 97 40 8a 00 00 00 00
(ada0:ahcich0:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 d0 fa 97 40 8a 00 00 01 00 00
(ada0:ahcich0:0:0:0): RES: 41 10 d0 fa 97 40 8a 00 00 00 00
(ada0:ahcich0:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 d0 fb 97 40 8a 00 00 01 00 00
(ada0:ahcich0:0:0:0): RES: 41 10 d0 fb 97 40 8a 00 00 00 00
(ada0:ahcich0:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 d0 fc 97 40 8a 00 00 01 00 00
(ada0:ahcich0:0:0:0): RES: 41 10 d0 fc 97 40 8a 00 00 00 00
(ada0:ahcich0:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 58 65 9f 40 8a 00 00 01 00 00
(ada0:ahcich0:0:0:0): RES: 41 10 58 65 9f 40 8a 00 00 00 00
ahcich0: Timeout on slot 18 port 0
ahcich0: is 00000000 cs 00040000 ss 00000000 rs 00040000 tfd c0 serr 00000000 cmd 0004d217
(ada0:ahcich0:0:0:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00
(ada0:ahcich0:0:0:0): CAM status: Command timeout
ahcich0: AHCI reset: device not ready after 31000ms (tfd = 00000080)
ahcich0: is 00000000 cs 00000000 ss 00000000 rs 00040000 tfd 150 serr 00000000 cmd 0004d217
(aprobe0:ahcich0:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00
(aprobe0:ahcich0:0:0:0): CAM status: Command timeout
(aprobe0:ahcich0:0:0:0): Error 5, Retry was blocked
