Patric Gustavsson
 - Jan 10, 2017
Trying to get freenas working on my system.
I am using an old HP Xw8200 Workstation with
Dual Xeon CPU
8gb ram
DeLock 89384 (it uses a ASM1061 chip) Sata Controller
And i am getting these error mesages in my logs :
an 10 05:26:20 freenas kernel: ahcich0: Timeout on slot 20 port 0
Jan 10 05:26:20 freenas kernel: ahcich0: is 00000000 cs 00000000 ss 00000000 rs 00100000 tfd 50 serr 00000000 cmd 0004df17
Jan 10 05:26:20 freenas kernel: (ada0:ahcich0:0:0:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00
Jan 10 05:26:20 freenas kernel: (ada0:ahcich0:0:0:0): CAM status: Command timeout
Jan 10 05:26:20 freenas kernel: (ada0:ahcich0:0:0:0): Retrying command
Jan 10 05:26:20 freenas kernel: ahcich4: Timeout on slot 8 port 0
Jan 10 05:26:20 freenas kernel: ahcich4: is 00000000 cs 00000000 ss 00000000 rs 00000100 tfd 50 serr 00000000 cmd 0004df17
Jan 10 05:26:20 freenas kernel: (ada1:ahcich4:0:0:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00
Jan 10 05:26:20 freenas kernel: (ada1:ahcich4:0:0:0): CAM status: Command timeout
Jan 10 05:26:20 freenas kernel: (ada1:ahcich4:0:0:0): Retrying command
(i cannot even list the contents of my zfs volume, it just locks up)
After having searched for these error messages, i found that somebody created a patch for this problem with my sata controller for Freebsd ;
https://www.mail-archive.com/svn-src-all@freebsd.org/msg133878.html
Is there a possibility for me to add this patch to my freenas install?
If so, any kind soul out there that has some hints on how i go about applying the patch?
Br
Patric
Dual Xeon CPU
8gb ram
Br
Patric
