diedrichg
- Dec 4, 2012
- FreeNAS 9.10.2.U2 STABLE
- Supermicro X10SLM-F-O uATX
- Intel G3420
- Kingston 16GB (8GB x 2) ECC w/Hynix DRAM, 1333MHz, 1.5V - KVR1333D3E9SK2/16G
- (4) WD Red 2TB in RaidZ2
- (2) Supermicro 16GB SATADOM boot drives in mirror - SSD-DM016-PHI
- 9.10 Plugin Jail: http://download.freenas.org/jails/9.10/x64/freenas-pluginjail-10.3-RELEASE.tgz
- Followed this guide: https://github.com/nZEDb/nZEDb/wiki/Install-Guide:-FreeNAS-(FreeBSD)
Issue: I'm getting a 502 Bad Gateway error on the http://192.168.1.51 jail address. I need some fresh eyes on this, please.
service nginx restart
service php-fpm restart
load_module /usr/local/libexec/nginx/ngx_mail_module.so;
load_module /usr/local/libexec/nginx/ngx_stream_module.so;
#user nobody;
worker_processes 1;
# This default error log path is compiled-in to make sure configuration parsing
# errors are logged somewhere, especially during unattended boot when stderr
# isn't normally logged anywhere. This path will be touched on every nginx
# start regardless of error log location configured here. See
# https://trac.nginx.org/nginx/ticket/147 for more info.
error_log /var/log/nginx/error.log;
#pid logs/nginx.pid;
events {
worker_connections 1024;
http {
include mime.types;
default_type application/octet-stream;
#log_format main '$remote_addr - $remote_user [$time_local] "$request" '
# '$status $body_bytes_sent "$http_referer" '
# '"$http_user_agent" "$http_x_forwarded_for"';
#access_log logs/access.log main;
sendfile on;
#tcp_nopush on;
#keepalive_timeout 0;
keepalive_timeout 65;
#gzip on;
include nzedb.conf;
# another virtual host using mix of IP-, name-, and port-based configuration
#server {
# listen 8000;
# listen somename:8080;
# server_name somename alias another.alias;
# location / {
# root html;
# index index.html index.htm;
# HTTPS server
#server {
# listen 443 ssl;
# server_name localhost;
# ssl_certificate cert.pem;
# ssl_certificate_key cert.key;
# ssl_session_cache shared:SSL:1m;
# ssl_session_timeout 5m;
# ssl_ciphers HIGH:!aNULL:!MD5;
# ssl_prefer_server_ciphers on;
# location / {
# root html;
server {
# Change these settings to match your machine.
listen 80;
# These are the log locations, you should not have to change these.
access_log /var/log/nginx-access.log;
error_log /var/log/nginx-error.log;
# This is the root web folder for nZEDb, you shouldn't have to change this.
root /usr/local/www/nZEDb/www/;
index index.php;
# Everything below this should not be changed unless noted.
location ~* \.(?:css|eot|gif|gz|ico|inc|jpe?g|js|ogg|oga|ogv|mp4|m4a|mp3|png|svg|ttf|txt|woff|xml)$ {
expires max;
add_header Pragma public;
add_header Cache-Control "public, must-revalidate, proxy-revalidate";
location / {
try_files $uri $uri/ @rewrites;
location ^~ /covers/ {
# This is where the nZEDb covers folder should be in.
root /usr/local/www/nZEDb/resources;
location @rewrites {
rewrite ^/([^/\.]+)/([^/]+)/([^/]+)/? /index.php?page=$1&id=$2&subpage=$3 last;
rewrite ^/([^/\.]+)/([^/]+)/?$ /index.php?page=$1&id=$2 last;
rewrite ^/([^/\.]+)/?$ /index.php?page=$1 last;
location ~ \.php$ {
include /usr/local/etc/nginx/fastcgi_params;
# Uncomment the following line and comment the .sock line if you want to use TCP.
# fastcgi_pass 127.0.0.1:9000;
fastcgi_pass unix:/var/run/php-fpm.sock;
# The next two lines should go in your fastcgi_params
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
