Hi Tekkie,
Thanx for your reply.
Since it is the FreeNAS 8 forum i presumed... But, it's a clean FreeNAS-8.0-RELEASE-i386 install, and i was not leaning on the keyboard ;)
I've also tried another USB stick (same result), but i guess if the stick was the problem it would not install on it in the first place.
I'm not really familiar with BSD, is there somehow i can get some on-screen messages/logs/debugging of sorts going so i can give you some sensible info?
Regards.
