antesilvam
- Mar 21, 2020
Dear all,
in the current Corona lock-down I finally find the time to start a project which I have in mind since quite a while. I would like to finally build my own FreeNAS server.
The requirements for the system are rather 'standard':
I went through the excellent hardware guides and came up with the following components:
Do you see problems with that hardware selection or do you have better recommendations for my use case?
The Motherboard comes directly with 6 SATA3 (via C232) and 8 SAS3 (via Broadcom 3008 SW controller) ports. Is there any preference which ports to use to connect the HDDs?
While looking around, I stumbled over the IMHO neat idea of running the FreeNAS server as a VM inside proxmox. This solution would help me to combine a few more services in one machine (which I run on different raspies at the moment), like:
* PLEX
* PiHole
* Unify controller
* VPN server
I found this interesting post in this forum where all the NAS storage is behind a PCI SAS controller which is then passed through directly to the FreeNAS VM: https://www.ixsystems.com/community/threads/standalone-freenas-migration-to-proxmox-freenas.81621/
What is your opinion on that option? Would you recommend this setup or should I better keep a storage server and other server tasks in seperated physical machines.
If you think it is a good idea to combine: Do you think the mentioned CPU is sufficient?
I would be very grateful for any recommendation or thoughts!
Thanks a lot!
Benedikt
- I want to use it mostly for backups and for storing/accessing/streaming photos and music.
- The data should be natively encrypted.
- 2-3 people might need to access data in parallel.
- Due to my current flat situation the server will have to share with me the living room, so the build should be at an acceptable noise level (ideally quiet). ;-)
CPU: Intel Core i3-6100
Motherboard: Supermicro X11SSL-CF (https://www.supermicro.com/en/products/motherboard/X11SSL-CF)
RAM: 2x16GB DDR4 2400MHz ECC
Storage: 1x64GB SDD (boot device)
5x WD Red 5TB 3.5" 5400RPM (planning to use RAID-Z1)
Storage Controller: SAS 3008 SAS3 controller (on board)Do you see problems with that hardware selection or do you have better recommendations for my use case?
* PLEX
* PiHole
* Unify controller
* VPN server
Thanks a lot!
Benedikt
