Pliqui
- Apr 24, 2018
Hello Community,
Long time lurker. Today I reach out to you to tap the collective knowledge of this site in order to trial by fire my build :D and ask a couple of suggestion regarding the build.
My current setup is:
CPU: Intel(R) Xeon(R) CPU W3550 @ 3.07GHz
Mobo: Lenovo Workstation S20
RAM: 24Gb non-ECC (maxed out)
Case: Fractal Design Define R5
Raid Controller: IBM ServeRaid M5015 (Cross-flashed to LSI 9260-8i)
HDD1: 1 x Samsumg 850 EVO 250gb SSD (Boot device for VMs)
HDD2: 4 x HGST 4TB in Raid5 (1 Datastore)
NIC: 1 x 1gb
I'm running ESXi 6.5 with VMs 10 running. Nothing high performance, but the machines that doesn't boot from the SSD are painfully slow, specially the Windows ones.
I decided to separate the storage from the compute (which someday down the road will be 2 or 3 mini itx servers). One added functionality to the FreeNAS is going to be plex.
Here are the specs of the new build: * Updated to reflect components changes.
CPU: Intel Xeon E3-1230 V6 Kaby Lake 3.5 GHz - Changed from E3-1225 V6
Mobo: SUPERMICRO MBD-X11SSL-CF Micro ATX*- Changed from SUPERMICRO MBD-X11SSH-F-O Micro ATX
RAM: 4 x Crucial CT16G4WFD824A 16Gb Ddr4 Ecc Unbuff Cl17 (64Gb maxed out)
Case: Fractal Design Node 804
PSU: Seasonic FOCUS Plus Series SSR-650FX 650W
Boot: 1 x SSD (I will use some old one I have around) - Added boot SSD - MiniSAS-to-SATA Mobo
HDD1: 4 x HGST 8TB stripped-mirror (presented over ISCSI to the ESXi server) - MiniSAS-to-SATA Mobo
HDD2: 4 x HGST 4TB (from current server) in Raidz1 (this for media, secondary backup place and non important stuff. A portion will be also presented to the ESXi via ISCSI) - SAS-to-SATA
HDD3: 1 x Intel Solid State Drive DC S3110 128GB stripped for ZLOG - Mobo SATA
SAS Cables: 2 x Supermicro MiniSAS HD to 4x SATA
NIC1: NetApp Chelsio Dual Port SFP+ 10GbE PCIe 111-00603+A0 CC2-S320E-SR 100-1082-00 - Direct connect to ESXi for ISCSI traffic (Ebay)
* Corrected model
Here are some points were I need some guidance:
.- Do a 10Gb NIC (2 actually) would worth the extra cost for the ISCSI direct connect?. In case yes, any cheap dual port 10gbe nic that works with ESXi 6.5 and FreeNAS?
Chelsio is a brand very popular in this forum, I checked the ESXi compatibility guide and looks like these are the only models supported in version 6.5, 6.5u1 and 6.7. The T520-BT, T520-CR, T520-LL-CR, T520-SO-CR which are not cheap.
.- I can't afford a PCIE SSD like the P3700, but I do care about my data, so I wanted to used a battery backup SSD: By stripping the 2 SSD, it will allow me to set the sync=always flag without massive dropping of performance. Any issues with this configuration ?
I do perform backups at several layers (VM and files) and keep a copy outside the array in separate disks.
Please note that no purchase of disks is required, already got them.
Any Suggestions, tip, 2 cents, etc are more than welcome and appreciate it.
Thanks guys.
NIC: 1 x 1gb
* Corrected model
Thanks guys.
