Help! Who can teach me how to install FlexGet on FreeNAS 9.1 JAIL.
useful_idiot
Much appreciated Scharbag, this got it installed happily. Now I've just gotta fix up my config.yml - my perfectly good config from my old WD MyBook Live system is getting errors when run on this... soon all will be good!
Thanks again.
Scharbag
Hmmm,
Seems like this changed in 9.3 again... Trying a couple things and will let you know what the deal is.
I have hit a wall with a py-sqlite error.
FATAL: Unable to use SQLite. Are you running Python 2.5 - 2.7 ?
Python should normally have SQLite support built in.
If you're running correct version of Python then it is not equipped with SQLite.
You can try installing `pysqlite`. If you have compiled python yourself, recompile it with SQLite support.
Anyone else figure out how to do a fresh install of FlexGet on a clean FreeNAS jail?
Scharbag
Got past the darn SQL problem. Strange that && make install clean in /usr/ports/databases/py-sqlite3 fails but the following worked:
pkg install databases/py-sqlite3
So, a little closer to complete.
Scharbag
Got it working.
Add storage to the jail via the FreeNAS gui
install the ports tree:
portsnap fetch extract update
upgrade installed packages:
pkg upgrade
run “&& make install clean” in (not all are needed for FlexGet but my config needs them):
/usr/ports/devel/py-pip
/usr/ports/net/rsync
/usr/ports/editors/nano
/usr/ports/achivers/rar
/usr/ports/achivers/unrar
pip install flexget
pip install —upgrade flexget
pip install transmissionrpc
pkg install databases/py-sqlite3 <— this is strange that the ports tree fails but this works…
remember to use "rehash" after the applications are installed.
Scharbag
Still having some issue with the execution when using thetvdb plugin but I don't know if that is the Jail or FlexGet 1.2.244. <-- it was a bug in 1.2.244 regarding the api_tvdb - fixed in 1.2.248.
Here is a simple shell script that will get FlexGet installed super fast in a standard jail in 9.3:
#!/bin/sh
pkg upgrade -y
pkg install -y net/py-urllib3 databases/py-sqlite3 devel/py-pip rar unrar nano
pip install --upgrade pip
pip install --upgrade setuptools
pip install flexget
pip install --upgrade flexget
pip install --upgrade transmissionrpc
If you update the packages, nano installs. Nano is NOT needed for FlexGet but I like it.
Cheers,
