Help ! what have I done _ update from 11.1 u6 train to 11.2 stable
Jeff Lamer
Please Help !
I updated from 11.1 to 11.2 and lost the ability to see my jails and plugins.
The goal was to update my jails (wardens) to iocage. I did confirm that my plugins are still working.
What should I do now ?
Thanks in Advance
Jeff
Have you looked at the legacy web interface?
The upgrade doesn't automatically do anything to your jails, but the new web interface does not show warden jails/plugins.
Jeff Lamer
Thanks sretalla,
Yes, I did figure out the legacy web interface. I am now trying to figure out how to update my current warden jails to iocage without screwing things up.
Is this the right way ?
iocage create -n "jailname" -p /tmp/pkg.json -r 11.1-RELEASE ip4_addr="vnet0|192.168.1.100/24" defaultrouter="192.168.1.1" vnet="on" allow_raw_sockets="1" boot="on"
Or should I just start from scratch ? ughh
kdragon75
Search the internet for "FreeNAS migrate from warden to iocage". The included script in 11.2 works well. Just know you may have to tweak a few things like mount points in the jails. It mostly painless and there are a number of great conversations on the forums here so I won't repeat everything.
Jeff Lamer
Thanks kdragon75,
I do search and read on the forum, that doesn't mean I "get it" or understand :).
So to start I shut down my sabnzbd jail (warden) and ran
migrate_warden.py -v -j <WARDEN> -p <POOL>
Now I need help with the "few tweaks" I now have the following error when I try to start the iocage in the new UI.
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 122, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 82, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 75, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 541, in start
iocage.start()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1628, in start
callback=self.callback
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 66, in __init__
self.__start_jail__()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 503, in __start_jail__
_callback=self.callback)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 81, in logit
_callback(content, exception)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 64, in callback
raise callback_exception(message)
RuntimeError:
Stopped sabnzbd_1 due to VNET failure
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 161, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1043, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 980, in _call
return await self._call_worker(serviceobj, name, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1007, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 938, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 923, in run_in_executor
RuntimeError:
kdragon75
Im no expert but it sounds like a jail network issue. I assume you are getting this error when trying to start the jail?
Can you pride the output of the following?
cat /mnt/iocage/jails/<JAILNAME>/config.json
ifconfig
Jeff Lamer
ifconfig[/QUOTE]
Sorry for long response
 "CONFIG_VERSION": "14",
	"allow_chflags": "0",
	"allow_mlock": "0",
	"allow_mount": "0",
	"allow_mount_devfs": "0",
	"allow_mount_nullfs": "0",
	"allow_mount_procfs": "0",
	"allow_mount_tmpfs": "0",
	"allow_mount_zfs": "0",
	"allow_quotas": "0",
	"allow_raw_sockets": "1",
	"allow_set_hostname": "1",
	"allow_socket_af": "0",
	"allow_sysvipc": "0",
	"allow_tun": "0",
	"available": "readonly",
	"basejail": "no",
	"boot": "on",
	"bpf": "no",
	"children_max": "0",
	"cloned_release": "EMPTY",
	"comment": "none",
	"compression": "lz4",
	"compressratio": "readonly",
	"coredumpsize": "off",
	"count": "1",
	"cpuset": "off",
	"cputime": "off",
	"datasize": "off",
	"dedup": "off",
	"defaultrouter": "none",
	"defaultrouter6": "none",
	"depends": "none",
	"devfs_ruleset": "4",
	"dhcp": "off",
	"enforce_statfs": "2",
	"exec_clean": "1",
	"exec_fib": "0",
	"exec_jail_user": "root",
	"exec_poststart": "/usr/bin/true",
	"exec_poststop": "/usr/bin/true",
	"exec_prestart": "/usr/bin/true",
	"exec_prestop": "/usr/bin/true",
	"exec_start": "/bin/sh /etc/rc",
	"exec_stop": "/bin/sh /etc/rc.shutdown",
	"exec_system_jail_user": "0",
	"exec_system_user": "root",
	"exec_timeout": "60",
	"host_domainname": "none",
	"host_hostname": "sabnzbd_1",
	"host_hostuuid": "sabnzbd_1",
	"host_time": "yes",
	"hostid": "00000000-0000-0000-0000-0CC47A693206",
	"hostid_strict_check": "off",
	"interfaces": "vnet0:bridge0",
	"ip4": "new",
	"ip4_addr": "vnet0|192.168.1.3/24",
	"ip4_saddrsel": "1",
	"ip6": "new",
	"ip6_addr": "none",
	"ip6_saddrsel": "1",
	"jail_zfs": "off",
	"jail_zfs_dataset": "iocage/jails/sabnzbd_1/data",
	"jail_zfs_mountpoint": "none",
	"last_started": "none",
	"login_flags": "-f root",
	"mac_prefix": "02ff60",
	"maxproc": "off",
	"memorylocked": "off",
	"memoryuse": "off",
	"mount_devfs": "1",
	"mount_fdescfs": "1",
	"mount_linprocfs": "0",
	"mount_procfs": "0",
	"mountpoint": "readonly",
	"msgqqueued": "off",
	"msgqsize": "off",
	"nmsgq": "off",
	"notes": "warden_id=2",
	"nsemop": "off",
	"nshm": "off",
	"nthr": "off",
	"openfiles": "off",
	"origin": "readonly",
	"owner": "root",
	"pcpu": "off",
	"priority": "99",
	"pseudoterminals": "off",
	"quota": "none",
	"release": "9.3-RELEASE",
	"reservation": "none",
	"resolver": "/etc/resolv.conf",
	"rlimits": "off",
	"securelevel": "2",
	"shmsize": "off",
	"stacksize": "off",
	"stop_timeout": "30",
	"swapuse": "off",
	"sync_state": "none",
	"sync_target": "none",
	"sync_tgt_zpool": "none",
	"sysvmsg": "new",
	"sysvsem": "new",
	"sysvshm": "new",
	"template": "no",
	"type": "jail",
	"used": "readonly",
	"vmemoryuse": "off",
	"vnet": "on",
	"vnet0_mac": "02837e000a0b 02837e000a0c",
	"vnet1_mac": "none",
	"vnet2_mac": "none",
	"vnet3_mac": "none",
	"vnet_default_interface": "none",
	"vnet_interfaces": "none",
	"wallclock": "off"
ifconfig
root@freenas:~ # ifconfig
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6>
		ether 0c:c4:7a:69:32:06
		hwaddr 0c:c4:7a:69:32:06
		inet 192.168.1.106 netmask 0xffffff00 broadcast 192.168.1.255
		media: Ethernet autoselect (1000baseT <full-duplex>)
		status: active
igb1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
		ether 0c:c4:7a:69:32:07
		hwaddr 0c:c4:7a:69:32:07
		status: no carrier
		options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
		inet6 ::1 prefixlen 128
		inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
		groups: lo
		ether 02:67:ee:c8:3f:00
		nd6 options=1<PERFORMNUD>
		groups: bridge
		member: vnet0:3 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 8 priority 128 path cost 2000
		member: vnet0:2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 6 priority 128 path cost 2000
		member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 5 priority 128 path cost 2000
		member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 1 priority 128 path cost 20000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=8<VLAN_MTU>
		ether 02:0c:d0:00:05:0a
		hwaddr 02:0c:d0:00:05:0a
		status: active
		groups: epair
vnet0:2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		description: associated with jail: sabnzbd_1
		options=8<VLAN_MTU>
		ether 02:83:7e:00:0a:0b
		hwaddr 02:0c:d0:00:06:0a
		status: active
		groups: epair
epair0b: flags=8842<BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=8<VLAN_MTU>
		ether 02:83:7e:00:0a:0c
		hwaddr 02:0c:d0:00:07:0b
		status: active
vnet0:3: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=8<VLAN_MTU>
		hwaddr 02:0c:d0:00:08:0a
		status: active
		groups: epair
kdragon75
Ok so it looks ok but the jail is insanely outdated...
You may consider trying iocage upgrade sabnzbd_1 -r 11.1-RELEASE
Also next time you need to post console output, use the [ code ] tags please.
kdragon75
Just a heads up, this is a long and SLOW process. Mine took about 30-40 minutes.
Jeff Lamer
I tried that command and recieved the following error;
kdragon75
Jeff Lamer
Gahh you need to start the jail to update it.
Ahhh this line:
You might just need to add a "," between the MAC addresses.
hmmm...tried that and jail still won't start. Same original error.
I really appreciate you trying to help me sort this out.
kdragon75
You can try just removing the MACs and they should be regenerated...
Another closer look and I see that vnet0:2 and vnet0:3 both are for sanbdz_1. Is the old jail running? this would cause conflict.
Jeff Lamer
All old jails have been shut down and rebooted FreeNas server several times. I removed MAC addresses and it rewrote them and still have same error trying to start jail.
	iocage.start()
RuntimeError:
	job,
RuntimeError:
kdragon75
Just remove the MAC, don't re-enter it.
Jeff Lamer
this is what I changed and saved in the config.json
"vnet0_mac": "none",
Then when I try to start the jail I get the usually error and then recheck config.json
"vnet0_mac": "02ff60583da8 02ff60583da9",
kdragon75
Well merp, I must be missing something.
Jeff Lamer
Darn..Thanks for trying :)
Anyone else have any ideas? anyone specific I could reach out to for help ?
