help to get started with sharing a HDD
paulskirk
Hi, I have some programming experience on microcontrollers, but new to cloud storage. I have a home router to which I can attach a HDD for NAS.
I'd like to be able to access the NAS for myself and a few other remote users (up to 5) and started looking at nextcloud. I visted the 'run nextcloud at home' page and got to 'run nextcloud on truenas'-> get started, but I couldn't work out my next step from the help pages. Could anyone give me a few pointers to get started?
thanks.
That's not a compatible set of options...
TrueNAS won't run on your home router.
Some home routers may be able to run third-party OS like Tomato/OpenWRT/dd-wrt (typically un-supported by the manufacturer and carries possible risks of "bricking" the router if not done properly), which provide such options (although maybe not a whole install of Nextcloud... more like CIFS/SMB shares, which would be OK for your home network side, but really discouraged for Internet-facing without some serious understanding of what you're doing with a firewall and probably a reverse proxy). natively in the product on compatible hardware. Other options are baked into the routers' factory OS, like for some ASUS and Synology routers.
If you just have a random whatever router that was supplied by your ISP, you may be out of luck.
The next few steps that would be relevant to this forum would be to buy or build a computer that's suitable to run TrueNAS (see https://www.truenas.com/community/resources/hardware-recommendations-guide.12/), then read enough of the docs (https://www.truenas.com/docs/, https://www.familybrown.org/dokuwiki/doku.php?id=fester112:intro, https://www.truenas.com/community/resources/introduction-to-zfs.111/) to understand how it and ZFS work. Then install it, create a storage pool, and install Nextcloud in a jail (if using TrueNAS CORE) or an App (if using SCALE).
An alternative (which wouldn't be at all relevant to this forum) would be to buy something like a Raspberry Pi and use NextcloudPi (https://docs.nextcloudpi.com/) to install Nextcloud on there.
paulskirk
Thanks very much for replies, much appreciated. It's made me realise it's probably too complex for me with my current limited knowledge and skill around networking and internet interfacing.
