Hi, I am quite new and inexperienced regarding shares, permissions and rsync. So, I need your help and advice.
I have an old Zyxel NAS 326, where my data currently are. I have built a new server based on Truenas scale and now I wan to migrate the data to it. I also want to keep the old nas for backups and use it as a replacement server for accessing the data in case of failure of the Truenas server. The only available method to sync data from Truenas to the Zyxel seems to be rsync, so I have setup an ssh connection between the two.
What I am struggling with is finding the most suitable setup options for user permissions (in the Truenas dataset that will hold the data) and rsync parameters for the sync between the two. Let me start with some facts:
1. We are a small office with 3 users. We use windows PCs to access the data via smb.
2. The Zyxel has very limited setup options regarding its shares and users. Currently we access our data using one guest account with no password. So basically, the data are open to everybody having access to our network. Creating new accounts IS possible in the Zyxel of course, but this is how is was setup initially.
3. Ideally, I would like to have a separate user account for each person in our office, so I can later setup additional smb shares for each user for e.g. personal data.
So, what would be best approach regarding data syncing? What would be the proper setup for rsync regarding permissions, owner, group, etc? My goal is to use the Zyxel for backups, but it should also be able to (temporarily) serve the data via smb in case of downtime/failure of the Truenas server.
Points 1-3 seem trivial to accomplish using in Truenas. For example, I was thinking using a dataset with nfsv4 acl and creating 4 users, all belonging to the same group: user1:office, user2:office, user3:office and office:office. Owner user of the dataset will be office and owner group will be office.
But then, is this the best setup? How does that affect compatibility when data are backed up in the zyxel? I am pretty sure the Zyxel does not support nfsv4 acl. So, what's left? Does it matter at all? I mean in case of Truenas server downtime, I don't care if all users can access the date from the Zyxel with the same account or if the data are open to the guest account, like they are now. It would be a temporarily thing anyway. Afterwards, if the data need be restored from the backup, I do not care if they are restored all having the same office:office owner and group, instead of the original user (user1, user2, user3, office) who created them.
I hope this is not too complicated to understand. I tried my best describing the situation. Any help would be appreciated. Thanks.
