(sorry for my bad English)
I have an old FreeNAS-9.10.2-U6 (561f0d7a1) running on an old HP Prolian MIcroserver (first gen). Using two desktop Seagate 4TB disk in mirror setup. This is the current status:
Now, the long history.
Last December, I got an email from the FreeNAS server getting lot of smart error in one of the disk. The disk was totally unusable. So, I just physically remove it from the server (my bad, yes). Then installed a new disk (the same, Seagate 4TB), and issued an
This is the first problem: I have a ghost device (2975835688515449866) which I can't remove. The
More problems: The READ, WRITE and CHSUM columns show a lot of errors. But CKSUM columns for the two disk show the same value ALWAYS.
I already checked both disk using smart test, both short and long tests returns no error. This is the results for the two disk:
I'm not an expert, but I think that disk are ok. So, why such big CKSUM errors ?
I have dismantled the server, cleaning all dust and connectors, and rebuild it to prevent failed cables or connectors (the server is very old). But still getting same errors.
But, I have check the data and seems to be correct. I can't find any corrupted file.
The only problem is the directory tmp from OpenVPN jail, which is listed as permanent error. It's like a black hole. You can copy or create any file, but
I already do a
I don't know what is the <0xffffffffffffffff>:<0x0> .... searching in Google don't give any clue.
More information: a
So, I'm totally stuck with this. I'm out of ideas.
Any help, please ???
Thanks!
  pool: zfs1
 state: DEGRADED
        corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
        entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: scrub repaired 0 in 46h25m with 1 errors on Tue Mar 26 01:26:29 2019
        zfs1                                            DEGRADED 1.65M     0 7.57K
          mirror-0                                      DEGRADED 6.58M     0 30.3K
            gptid/03cc6e09-df0f-11e5-9697-009c02a7fa32  DEGRADED     0     0 6.61M  too many errors
            2975835688515449866                         UNAVAIL      0     0     0  was /dev/gptid/9d79ca97-47f5-11e8-b3a4-009c02a7fa32
            gptid/b4dd3975-4f65-11e8-ab2f-009c02a7fa32  ONLINE       0     0 6.61M
        /mnt/zfs1/jails/OpenVPN/tmp
add command. Resilver started.This is the first problem: I have a ghost device (2975835688515449866) which I can't remove. The
detach command returns:Code:
[root@freenas] ~# zpool detach zfs1 2975835688515449866 cannot detach 2975835688515449866: no valid replicas [root@freenas] ~# zpool detach zfs1 /dev/gptid/9d79ca97-47f5-11e8-b3a4-009c02a7fa32 cannot detach /dev/gptid/9d79ca97-47f5-11e8-b3a4-009c02a7fa32: no valid replicas
[root@freenas] ~# smartctl -a /dev/ada0
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Seagate Barracuda 3.5
Device Model:     ST4000DM004-2CV104
Serial Number:    ZFN14JSY
LU WWN Device Id: 5 000c50 0aff03e78
Firmware Version: 0001
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5425 rpm
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Mon Apr 15 21:13:26 2019 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (    0) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 484) minutes.
Conveyance self-test routine
SCT capabilities:              (0x30a5) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   084   064   006    Pre-fail  Always       -       240686392
  3 Spin_Up_Time            0x0003   097   097   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       16
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   092   060   045    Pre-fail  Always       -       1542408167
  9 Power_On_Hours          0x0032   091   091   000    Old_age   Always       -       8474 (177 116 0)
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       16
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       0 0 2
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   072   061   040    Old_age   Always       -       28 (Min/Max 25/29)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       276
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       352
194 Temperature_Celsius     0x0022   028   040   000    Old_age   Always       -       28 (0 20 0 0 0)
195 Hardware_ECC_Recovered  0x001a   084   064   000    Old_age   Always       -       240686392
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       8439h+10m+11.326s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       20354682795
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       101287520165
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%      8458         -
# 2  Short offline       Completed without error       00%      8445         -
# 3  Short offline       Completed without error       00%      8410         -
# 4  Short offline       Completed without error       00%      8362         -
# 5  Short offline       Completed without error       00%      8314         -
# 6  Short offline       Completed without error       00%      8266         -
# 7  Short offline       Completed without error       00%      8218         -
# 8  Short offline       Completed without error       00%      8170         -
# 9  Extended offline    Completed without error       00%      8134         -
#10  Short offline       Completed without error       00%      8051         -
#11  Short offline       Completed without error       00%      8004         -
#12  Short offline       Completed without error       00%      7955         -
#13  Short offline       Completed without error       00%      7907         -
#14  Short offline       Completed without error       00%      7859         -
#15  Short offline       Completed without error       00%      7811         -
#16  Extended offline    Completed without error       00%      7779         -
#17  Short offline       Completed without error       00%      7715         -
#18  Short offline       Completed without error       00%      7667         -
#19  Short offline       Completed without error       00%      7619         -
#20  Short offline       Completed without error       00%      7571         -
#21  Short offline       Completed without error       00%      7523         -
[root@freenas] ~# smartctl -a /dev/ada1
Serial Number:    ZFN0GWZD
LU WWN Device Id: 5 000c50 0a4b23fe1
Local Time is:    Mon Apr 15 21:15:55 2019 CEST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 473) minutes.
  1 Raw_Read_Error_Rate     0x000f   075   064   006    Pre-fail  Always       -       29218056
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       8
  7 Seek_Error_Rate         0x000f   092   060   045    Pre-fail  Always       -       1560721189
  9 Power_On_Hours          0x0032   091   091   000    Old_age   Always       -       8252 (215 250 0)
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       8
190 Airflow_Temperature_Cel 0x0022   072   051   040    Old_age   Always       -       28 (Min/Max 26/29)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       233
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       333
194 Temperature_Celsius     0x0022   028   049   000    Old_age   Always       -       28 (0 20 0 0 0)
195 Hardware_ECC_Recovered  0x001a   075   064   000    Old_age   Always       -       29218056
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       8219h+20m+48.654s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       47000063073
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       56545103875
No Errors Logged
# 1  Short offline       Completed without error       00%      8236         -
# 2  Short offline       Completed without error       00%      8223         -
# 3  Short offline       Completed without error       00%      8188         -
# 4  Short offline       Completed without error       00%      8143         -
# 5  Short offline       Completed without error       00%      8092         -
# 6  Short offline       Completed without error       00%      8044         -
# 7  Short offline       Completed without error       00%      7997         -
# 8  Short offline       Completed without error       00%      7948         -
# 9  Extended offline    Completed without error       00%      7901         -
#10  Short offline       Completed without error       00%      7830         -
#11  Short offline       Completed without error       00%      7781         -
#12  Short offline       Completed without error       00%      7733         -
#13  Short offline       Completed without error       00%      7685         -
#14  Short offline       Completed without error       00%      7637         -
#15  Short offline       Completed without error       00%      7589         -
#16  Extended offline    Completed without error       00%      7556         -
#17  Short offline       Completed without error       00%      7493         -
#18  Short offline       Completed without error       00%      7445         -
#19  Short offline       Completed without error       00%      7397         -
#20  Short offline       Completed without error       00%      7349         -
#21  Short offline       Completed without error       00%      7301         -
ls return 0 files.I already do a
scrub command several times, but always ends with 0 recovery and 1 error, which I think is the tmp directory.I don't know what is the <0xffffffffffffffff>:<0x0> .... searching in Google don't give any clue.
More information: a
zpool clear command only start a resilver and ends with same situation. Rebooting the server starts a resilver again and end with same situation. Resilver always go from first disk in list (the old good disk) to the second disk on list (new and good disk).So, I'm totally stuck with this. I'm out of ideas.
Thanks!
