/dev/da5 [SAT], Failed SMART usage Attribute: 5 Reallocated_Sector_Ct
VioletDragon
Resilver is done and the error has also disappeared. Will keep an eye on it tho.
% zpool status tank
  pool: tank
 state: ONLINE
  scan: resilvered 1.22T in 0 days 03:17:55 with 0 errors on Thu May 14 04:30:54 2020
    tank                                            ONLINE       0     0     0
      raidz2-0                                      ONLINE       0     0     0
        gptid/aefe11fe-2ec9-11ea-9e3c-0017087d2e9a  ONLINE       0     0     0
        gptid/a0c03cbe-4259-11ea-a71e-0017087d2e9a  ONLINE       0     0     0
        gptid/f08b6925-591c-11ea-86a6-0017087d2e9a  ONLINE       0     0     0
        gptid/b167c1e0-2ec9-11ea-9e3c-0017087d2e9a  ONLINE       0     0     0
        gptid/975212ff-9577-11ea-b683-00074309b09a  ONLINE       0     0     0
        gptid/b38af215-2ec9-11ea-9e3c-0017087d2e9a  ONLINE       0     0     0
errors: No known data errors
VioletDragon
Update.
This issue is solved and has not come back. Can be marked as solved.
Thanks.
fbl29?2@
I've been getting emails sent to me from Proxmox; "Device: /dev/sdc [SAT], Failed SMART usage Attribute: 5 Reallocated_Sector_Ct." ever since I replaced two 3tb Western Digital drives with two 8tb Seagate drives. Same for Device: /dev/sdd/
I received the following message: "
Device info:
WDC WD30EZRX-00D8PB0, S/N:WD-WCC4N3RRHC81, WWN:5-0014ee-20b8fd2e0, FW:80.00A80, 3.00 TB" which shows 3.00 TB. The new drives are 8TB and Seagate so any help with this error message would be great as it really doesn't make any sense as error message is referencing two drives that are not physical in my NAS. The two 8TB drives are ST8000VN004-2M2101_WSD84G3R and ST8000VN004-2M2101_WSD84HHB.
Also, SMART tests show everything is good.
You're more likely to find useful advice somewhere more Proxmox-adjacent, especially since whatever alerting system Proxmox uses will have little to do with TrueNAS'.
