Hi folks,
Here is my current config:
- HP proliant microserver G8, boot on a USB key, 1 RAIDZ1 volume (4 HDD) for data, 1 volume on an intel 32GB SLC SSD for system dataset (thus allowing the 4 HDD in the RAIDZ1 array to standby when unused)
The B120i raid storage controller is disabled, I use the default SATA controller.
the result of zpool status is:
What I would like to do:
- Use the IBM M1015 card (IT mode) that I bought as storage controller
- Use the Intel 32Gb as a boot device AND system dataset volume (it is possible ?) because I don't think booting the OS on a USB key is the way to go
But I'm not sure on how to proceed. I saved my system config file.
But what are the next steps ?
Any help or advices would be really appreciated.
pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0h9m with 0 errors on Thu Nov 17 03:54:58 2016 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 gptid/54906f79-dc79-11e4-99cb-a0481cb8dad4 ONLINE 0 0 0 errors: No known data errors pool: volume1 state: ONLINE status: Some supported features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(7) for details. scan: scrub repaired 0 in 8h59m with 0 errors on Tue Nov 1 10:59:46 2016 config: NAME STATE READ WRITE CKSUM volume1 ONLINE 0 0 0 raidz1-0 ONLINE 0 0 0 gptid/a6162ed9-1ff5-11e4-ae52-a0481cb8dad4 ONLINE 0 0 0 gptid/a6647819-1ff5-11e4-ae52-a0481cb8dad4 ONLINE 0 0 0 gptid/a6b82bca-1ff5-11e4-ae52-a0481cb8dad4 ONLINE 0 0 0 gptid/a70a70b2-1ff5-11e4-ae52-a0481cb8dad4 ONLINE 0 0 0 errors: No known data errors pool: volume2 state: ONLINE status: Some supported features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(7) for details. scan: scrub repaired 0 in 0h0m with 0 errors on Tue Nov 1 01:00:01 2016 config: NAME STATE READ WRITE CKSUM volume2 ONLINE 0 0 0 gptid/c11cea72-27a4-11e4-b1fd-a0481cb8dad4 ONLINE 0 0 0 errors: No known data errors
