olger
- Nov 11, 2013
Hello everyone!
So after about 6 months of using FreeNAS & ZFS I've started feeling somewhat comfortable with it. I just bought a UPS & 16 GB of memory for my system, and now consider myself done with the setup. I should clarify, I mean "done" in the sense that I don't know anything else I can do to protect my data. And that's why I'm here. I'm looking for input, any input at all, regarding data safety (or other improvements). Backups are done on a regular basis, of course.
Let me start off by giving you some specs & information. I'm running a HP MicroServer (N54L) with 2x WD Red 3TB in a mirror & 16 GB RAM instead of the 2 GB that came with the machine. I also have a UPS all set up, solely for the NAS. I boot FreeNAS off a USB-memory.
The NAS is built for home usage, and is used by a 4-person family. We store just about everything on it. Usually there is not more than 1 or 2 people using it at the same time, we are very pleased with the performance so far.
The UPS is newly installed, and has been function-tested after setup. I changed the upsmon password. Configuration was quite basic, I think that about covers all you need about the UPS? I plan on doing some form of battery-test on a yearly basis.
The RAM is also fresh off the shelves. Ran 3 passes of memtest, took a little over 6 hours, no errors. It shows up in the system information in FreeNAS. Is there anything I should do, considering I ran FreeNAS & ZFS on 2 GB (I know, I know, playing with fire is bad) for 6 months?
Posted previously to get some help with ZFS Scrubs & SMART tests, here's what they look like:
I think that about covers it, let me know if I missed something. All input is very welcome!
