Help, issue with volume storage size reporting
yonkoc
Build FreeNAS-8.2.0-RELEASE-p1-x64 (r11950)
Platform Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz
Memory 16287MB
GUI and CLI report not issues with the pool.
Hello, I have 3x 2Tb in a mirrored with a spare configuration, which netted me ~1.7-1.9TB of mirrored storage. The box is attached to a domain so I can use the domain admin/user permissions. I got some issues with permissions on one of the top level backup folders and I ended up not being able to delete anything via Windows. Which, while not okay, was not that big of a problem. I then created a new folder and all permissions worked as intended. I started moving the data and re-assigned our backup software to the new location. All was working fine. And today I decided to get rid of the old sub-folders of the one with the bad permissions and started deleting them one by one. I used CLI and I am certain I did not do anything stupid with rm -rf as I would simply use the up arrow to recall the last command and change the name to a different subfolder. Ex. rm -rf /mnt/Backup630/Office_Backup/BadFolderPermissions/Subfolder1. Executing this command eliminates Subfolder1. Pressing the up arrow key I'd change Subfolder1 to Subfolder2 (if the name is sub folder 2, I'd do ........./BadfolderPermissions/"Sub Folder 2" and it eliminates it without any issues). I disabled the Recycle option for this exercise as I did not want to go and delete them twice.
All of a sudden, while transferring one of the last few remaining folders from the one with the bad permissions to the new one, it popped a message saying "destination folder not available" and stopped the transfer of data (was doing this under Windows). Which was odd. What was even weird is that now the size of the volume is reported as not ~1.7-1.9Tb but 571GB. I wish I'd taken a photo of the diskspace reporting tool before I exported and reimported the pool but it was a showing a slope, receding from 930GB to the 571GB (so there must have been another drop from 1.7-1.9TB prior to me finding out about it) that it is now with a few steps inbetween. I have no idea what's going on. I tried exporting and reimporting the pool, rebooted but nothing. It now shows 571 as the total storage of that volume. My thoughts are that the space that I was freeing up is... well getting erased and I have not idea how. It is as if the volume manager reduces the volume size when I delete a folder proportionally to its size. I am pretty certain one of the folders was close to 200GB and the others were around 150GB so that would account for those.
Any ideas?
yonkoc
I am including a few more bits of info, and it is actually 3 x 2TB (have a different client with 3 x 1TB):
zpool list
[root@KW630NAS] ~# zpool list
NAME        SIZE   USED  AVAIL    CAP  HEALTH  ALTROOT
Backup630  1.81T  1.68T   136G    92%  ONLINE  /mnt
gpart show
[root@KW630NAS] ~# gpart show
=>     63  7716744  da0  MBR  (3.7G)
       63  1930257    1  freebsd  [active]  (943M)
  1930320       63       - free -  (32K)
  1930383  1930257    2  freebsd  (943M)
  3860640     3024    3  freebsd  (1.5M)
  3863664    41328    4  freebsd  (20M)
  3904992  3811815       - free -  (1.8G)
=>      0  1930257  da0s1  BSD  (943M)
        0       16         - free -  (8.0K)
       16  1930241      1  !0  (943M)
=>      0  1930257  da0s2  BSD  (943M)
=>        34  3907029101  ada0  GPT  (1.8T)
          34          94        - free -  (47K)
         128     4194304     1  freebsd-swap  (2.0G)
     4194432  3902834703     2  freebsd-zfs  (1.8T)
=>        34  3907029101  ada1  GPT  (1.8T)
=>        34  3907029101  ada2  GPT  (1.8T)
zpool status -v
[root@KW630NAS] ~# zpool status -v
  pool: Backup630
 state: ONLINE
 scrub: scrub in progress for 2h43m, 35.82% done, 4h53m to go
	Backup630   ONLINE       0     0     0
	  mirror    ONLINE       0     0     0
	    ada0p2  ONLINE       0     0     0
	    ada1p2  ONLINE       0     0     0
	spares
	  ada2p2    AVAIL
errors: No known data errors
zfs list
[root@KW630NAS] ~# zfs list
NAME        USED  AVAIL  REFER  MOUNTPOINT
Backup630  1.68T   107G   464G  /mnt/Backup630
df -h
[root@KW630NAS] ~# df -h
Filesystem             Size    Used   Avail Capacity  Mounted on
/dev/ufs/FreeNASs1a    927M    359M    494M    42%    /
devfs                  1.0K    1.0K      0B   100%    /dev
/dev/md0               4.6M    1.8M    2.4M    43%    /etc
/dev/md1               824K    2.0K    756K     0%    /mnt
/dev/md2               149M     10M    127M     7%    /var
/dev/ufs/FreeNASs4      20M    1.5M     17M     8%    /data
Backup630              571G    464G    107G    81%    /mnt/Backup630
/dev/md3               1.9G    626K    1.7G     0%    /var/tmp/.cache
dmesg.boot
[root@KW630NAS] ~# cat /var/run/dmesg.boot
Waiting (max 60 seconds) for system process `vnlru' to stop...done
Waiting (max 60 seconds) for system process `bufdaemon' to stop...done
Waiting (max 60 seconds) for system process `syncer' to stop...
Syncing disks, vnodes remaining...1 0 0 0 done
All buffers synced.
Copyright (c) 1992-2011 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
	The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 8.2-RELEASE-p9 #0: Thu Jul 19 12:39:10 PDT 2012
    root@build.ixsystems.com:/build/home/jpaetzel/8.2.0/os-base/amd64/build/home/jpaetzel/8.2.0/FreeBSD/src/sys/FREENAS.amd64 amd64
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz (3109.15-MHz K8-class CPU)
  Origin = "GenuineIntel"  Id = 0x206a7  Family = 6  Model = 2a  Stepping = 7
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
  Features2=0x159ae3bf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,POPCNT,<b24>,XSAVE,<b28>>
  AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
  AMD Features2=0x1<LAHF>
  TSC: P-state invariant
real memory  = 17179869184 (16384 MB)
avail memory = 16454332416 (15692 MB)
ACPI APIC Table: <GBT    GBTUACPI>
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s) x 2 SMT threads
 cpu0 (BSP): APIC ID:  0
 cpu1 (AP): APIC ID:  1
 cpu2 (AP): APIC ID:  2
 cpu3 (AP): APIC ID:  3
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0: Changing APIC ID to 2
ioapic0 <Version 2.0> irqs 0-23 on motherboard
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
acpi0: <GBT GBTUACPI> on motherboard
acpi0: [ITHREAD]
acpi0: Power Button (fixed)
acpi0: reservation of 0, a0000 (3) failed
acpi0: reservation of 100000, dae80000 (3) failed
Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
acpi_button0: <Power Button> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
vgapci0: <VGA-compatible display> port 0xff00-0xff3f mem 0xfb800000-0xfbbfffff,0xe0000000-0xefffffff irq 16 at device 2.0 on pci0
pci0: <simple comms> at device 22.0 (no driver attached)
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfbffe000-0xfbffe3ff irq 18 at device 26.0 on pci0
ehci0: [ITHREAD]
usbus0: EHCI version 1.0
usbus0: <EHCI (generic) USB 2.0 controller> on ehci0
pci0: <multimedia, HDA> at device 27.0 (no driver attached)
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> irq 18 at device 28.6 on pci0
pci2: <ACPI PCI bus> on pcib2
re0: <RealTek 8168/8111 B/C/CP/D/DP/E PCIe Gigabit Ethernet> port 0xee00-0xeeff mem 0xfbdff000-0xfbdfffff,0xfbdf8000-0xfbdfbfff irq 18 at device 0.0 on pci2
re0: Using 1 MSI-X message
re0: Chip rev. 0x2c800000
re0: MAC rev. 0x00000000
miibus0: <MII bus> on re0
rgephy0: <RTL8169S/8110S/8211B media interface> PHY 1 on miibus0
rgephy0:  10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
re0: Ethernet address: 50:e5:49:e3:5f:17
re0: [ITHREAD]
pcib3: <ACPI PCI-PCI bridge> irq 19 at device 28.7 on pci0
pci3: <ACPI PCI bus> on pcib3
pci3: <serial bus, USB> at device 0.0 (no driver attached)
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xfbffd000-0xfbffd3ff irq 23 at device 29.0 on pci0
ehci1: [ITHREAD]
usbus1: EHCI version 1.0
usbus1: <EHCI (generic) USB 2.0 controller> on ehci1
pcib4: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci4: <ACPI PCI bus> on pcib4
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
ahci0: <Intel Cougar Point AHCI SATA controller> port 0xfe00-0xfe07,0xfd00-0xfd03,0xfc00-0xfc07,0xfb00-0xfb03,0xfa00-0xfa1f mem 0xfbffc000-0xfbffc7ff irq 19 at device 31.2 on pci0
ahci0: [ITHREAD]
ahci0: AHCI v1.30 with 6 6Gbps ports, Port Multiplier supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich0: [ITHREAD]
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich1: [ITHREAD]
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich2: [ITHREAD]
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich3: [ITHREAD]
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich4: [ITHREAD]
ahcich5: <AHCI channel> at channel 5 on ahci0
ahcich5: [ITHREAD]
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff irq 0,8 on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 900
atrtc0: <AT realtime clock> port 0x70-0x73 on acpi0
orm0: <ISA Option ROM> at iomem 0xc0000-0xcdfff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbd0: [ITHREAD]
ppc0: cannot reserve I/O port range
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
coretemp0: Tj(target) value 102 does not seem right.
est0: <Enhanced SpeedStep Frequency Control> on cpu0
p4tcc0: <CPU Frequency Thermal Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
coretemp1: Tj(target) value 102 does not seem right.
est1: <Enhanced SpeedStep Frequency Control> on cpu1
p4tcc1: <CPU Frequency Thermal Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
coretemp2: Tj(target) value 102 does not seem right.
est2: <Enhanced SpeedStep Frequency Control> on cpu2
p4tcc2: <CPU Frequency Thermal Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
coretemp3: Tj(target) value 102 does not seem right.
est3: <Enhanced SpeedStep Frequency Control> on cpu3
p4tcc3: <CPU Frequency Thermal Control> on cpu3
fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Timecounters tick every 1.000 msec
usbus0: 480Mbps High Speed USB v2.0
usbus1: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
ugen1.1: <Intel> at usbus1
uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
ugen0.2: <vendor 0x8087> at usbus0
uhub2: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus0
ugen1.2: <vendor 0x8087> at usbus1
uhub3: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus1
uhub2: 6 ports with 6 removable, self powered
uhub3: 8 ports with 8 removable, self powered
ugen0.3: <vendor 0x05e3> at usbus0
umass0: <vendor 0x05e3 USB Flash Disk, class 0/0, rev 2.00/2.07, addr 3> on usbus0
(probe0:umass-sim0:0:0:0): TEST UNIT READY. CDB: 0 0 0 0 0 0
(probe0:umass-sim0:0:0:0): CAM status: SCSI Status Error
(probe0:umass-sim0:0:0:0): SCSI status: Check Condition
(probe0:umass-sim0:0:0:0): SCSI sense: UNIT ATTENTION asc:28,0 (Not ready to ready change, medium may have changed)
ada0 at ahcich2 bus 0 scbus2 target 0 lun 0
ada0: <ST2000DL003-9VT166 CC32> ATA-8 SATA 3.x deviceda0 at umass-sim0 bus 0 scbus6 target 0 lun 0
da0: < USB Flash Disk 0207> Removable Direct Access SCSI-0 device
da0: 40.000MB/s transfers
da0: 3768MB (7716864 512 byte sectors: 255H 63S/T 480C)
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada1 at ahcich3 bus 0 scbus3 target 0 lun 0
ada1: <ST2000DL003-9VT166 CC32> ATA-8 SATA 3.x device
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada2 at ahcich4 bus 0 scbus4 target 0 lun 0cd0 at ahcich5 bus 0 scbus5 target 0 lun 0
cd0: <ASUS DRW-24B1ST   a 1.04> Removable CD-ROM SCSI-0 device
cd0: 150.000MB/s transfers (SATA 1.x, UDMA5, ATAPI 12bytes, PIO 8192bytes)
cd0: Attempt to query device size failed: NOT READY, Medium not present - tray closed
ada2: <ST2000DL003-9VT166 CC32> ATA-8 SATA 3.x device
ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
SMP: AP CPU #1 Launched!
SMP: AP CPU #3 Launched!
SMP: AP CPU #2 Launched!
GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
GEOM: da0s2: geometry does not match label (16h,63s != 255h,63s).
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
ZFS filesystem version 4
ZFS storage pool version 15
Syncing disks, vnodes remaining...0 0 0 done
All buffers synced.
CPU: Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz (3109.16-MHz K8-class CPU)
kbd1 at kbdmux0
acpi0: [ITHREAD]
ehci0: [ITHREAD]
re0: [ITHREAD]
ehci1: [ITHREAD]
ahci0: [ITHREAD]
ahcich0: [ITHREAD]
ahcich1: [ITHREAD]
ahcich2: [ITHREAD]
ahcich3: [ITHREAD]
ahcich4: [ITHREAD]
ahcich5: [ITHREAD]
kbd0 at atkbd0
atkbd0: [ITHREAD]
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)da0 at umass-sim0 bus 0 scbus6 target 0 lun 0
ada2: 300.000MB/s transferscd0 at ahcich5 bus 0 scbus5 target 0 lun 0
All buffers synced.
kbd1 at kbdmux0
acpi0: [ITHREAD]
ehci0: [ITHREAD]
re0: [ITHREAD]
ehci1: [ITHREAD]
ahci0: [ITHREAD]
ahcich0: [ITHREAD]
ahcich1: [ITHREAD]
ahcich2: [ITHREAD]
ahcich3: [ITHREAD]
ahcich4: [ITHREAD]
ahcich5: [ITHREAD]
kbd0 at atkbd0
atkbd0: [ITHREAD]
