Help installing vm
maddoc
My problem regards virtual machines on freenas... how can I install one? I have several iso of windows xp, windows 10 and windows server
When I select uefi CSM the system hangs at installation (I can see it using vnc)
If i do select simple uefi I can't log in using vnc so I do not know what happen
How can I solve that? How can I control the installation in uefi-csm mode?
Is it possible to boot a virtual machine installation using a usb pen drive install?
Thanks to everybody may help me
adrianwi
Type exit and hit enter, then enter again on the next screen, and assuming you've mounted the .iso file as a CDROM drive your OS boot/install process should start.
maddoc
Thanks for replying! In Uefi-csm how can i connect to the vm? can't use vnc!
You don't need UEFI CSM (that's only for OSes that install over serial/text interface)
