Hey guys,
Just recently re-built my Freenas server with a fresh install of 11.3-U2.1 . As far as Freenas goes everything is working as expected.
However, when trying to install Plex plugin i get this error:
Error: PlexServer had a failure Exception: RuntimeError Message: pkg error: - pkg-static: Repository iocage-plugins cannot be opened. 'pkg update' required pkg-static: No packages available to install matching 'pkg' have been found in the repositories Please check your network Partial plugin destroyed
Any ideas as to what could be causing this ?
When installing the plugin i leave all settings at default.
Thank you :)
Thank you :)
