freebsdsa
- Feb 26, 2014
I know, I know... Use the GUI... Lets get past that part and on the helping.
Here is the gist of my problem...
Working on a FreeNAS 11.1 server with three pools on it. I just setup the third pool and was getting some zvol settings dialed in via command line to match what we do on the other two pools. I use the command line as I want to setup the volsize greater than 80% of storage size and the GUI does not let me... I had just set the volsize and wanted to look at and compare all the other settings. I hit the up arrow to do a "zfs get all" and I adjusted the command line to point to one of my production datasets. I was not paying attention and I guess I hit the down arrow on my keyboard, I change to command to point to one of the current prod zvols and hit return. It was then I realized I set/shrank the volsize from 200T to 25T on the prod zvol. The command has not returned yet and things are starting to look bad. I can not cancel the command "cntrl-c". So how screwed am I? Will I lose data?
