Recently, I have started seeing this error on the connected display monitor, and in /var/log/message log file:
READ command returned errno 5 --> every 3 seconds.
and
WRITE command returned errno 5 --> every 30 seconds.
the full error line is:
<date> 01:50:30 <hostname> (2:4:0/0): READ command returned errno 5 --> the node indicator (?) in parenthesis (2:4:0/0) changes throughout the file between 0:4:0/0 - thru 3:4:0/0
my system:
FreeBSD 9.3-RELEASE-p5 #0 3b4abc3: Mon Dec 8 15:09:41 PST 2014 root@build3.ixsystems.com:/tank/home/jkh/build/M/FN/objs/os-base/amd64/fusion/jkh/M/FN/FreeBSD/src/sys/FREENAS.amd64
Running on HP DL180G6, using P410 RAID ctrl. with 6x150GB drives (RAID10), and 6x450GB drives (RAID5) - presenting to FreeNAS only the two arrays as disk (not using ZFS tools or utils).
Have 3 identical servers, two PROD, one LAB - only one of them (one of the PRODs) has this issue. Haven't noticed (or heard from users) of any degradation in performance, everything seems to be working well otherwise.
Not sure where to start looking.... Any input will be appreciated!
TY,
/DL
and
my system:
TY,
/DL
