Nightly security output, v9.2.1.5
shapiros
Been running FreeNAS 8.3.1 for several years on 2 NAS boxes, each containing 5, 3TB hard drives with a 30GB SSD drive for my boot device. Devices have been running great. Usual HD failures, replacement as per the manual with absolutely no hiccups whatsoever. Decided to upgrade these boxes to 9.2.1.5 but before doing so, thoroughly read the manual and other available documentation. Knew that I would no longer get the nightly zpool status but do get bombarded with the following on a nightly basis (had to prune it to 30k chars). Is there a way to turn this off? May have missed it in the manual. Also, the upgraded NAS randomly slows down considerably. Even the web GUI becomes unresponsive. The motherboard is an old ASUS with an on-board AMD 1GHZ dual core processor with 8GB memory. I realize that the FreeNAS team doesn't like ASUS. However, needing 6 sata ports does limit ones options. Any insight regarding the nightly security output would be greatly appreciated. I realize the "slowdowns" will be impossible to troubleshoot via these forums.
FreeNAS-10TR.local kernel log messages:
> Copyright (c) 1992-2013 The FreeBSD Project.
> Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
> The Regents of the University of California. All rights reserved.
> FreeBSD is a registered trademark of The FreeBSD Foundation.
> FreeBSD 9.2-RELEASE-p4 #0 r262572+17a4d3d: Wed Apr 23 10:09:38 PDT 2014
root@build3.ixsystems.com:/tank/home/jkh/build/9.2.1/freenas/os-base/amd64/fusion/jkh/9.2.1/freenas/FreeBSD/src/sys/FREENAS.amd64
amd64
> gcc version 4.2.1 20070831 patched [FreeBSD]
> CPU: AMD C-60 APU with Radeon(tm) HD Graphics (1000.02-MHz K8-class CPU)
> Origin = "AuthenticAMD" Id = 0x500f20 Family = 0x14 Model = 0x2 Stepping = 0
Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
> Features2=0x802209<SSE3,MON,SSSE3,CX16,POPCNT>
> AMD Features=0x2e500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM>
> AMD Features2=0x35ff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,IBS,SKINIT,WDT>
> TSC: P-state invariant, performance statistics
> real memory = 8589934592 (8192 MB)
> avail memory = 7809134592 (7447 MB)
> Event timer "LAPIC" quality 400
> ACPI APIC Table: <ALASKA A M I>
> FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
> FreeBSD/SMP: 1 package(s) x 2 core(s)
> cpu0 (BSP): APIC ID: 0
> cpu1 (AP): APIC ID: 1
> WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
> ACPI Warning: Optional field Pm2ControlBlock has zero address or length: 0x0000000000000000/0x1
(20110527/tbfadt-586)
> ioapic0: Changing APIC ID to 0
> ioapic0 <Version 2.1> irqs 0-23 on motherboard
> kbd1 at kbdmux0
> cryptosoft0: <software crypto> on motherboard
> aesni0: No AESNI support.
> padlock0: No ACE support.
> acpi0: <ALASKA A M I> on motherboard
> ACPI Error: [RAMB] Namespace lookup failure, AE_NOT_FOUND (20110527/psargs-392)
> ACPI Exception: AE_NOT_FOUND, Could not execute arguments for [RAMW] (Region)
(20110527/nsinit-380)
> acpi0: Power Button (fixed)
> cpu0: <ACPI CPU> on acpi0
> cpu1: <ACPI CPU> on acpi0
> attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
> Timecounter "i8254" frequency 1193182 Hz quality 0
> Event timer "i8254" frequency 1193182 Hz quality 100
> atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
> Event timer "RTC" frequency 32768 Hz quality 0
> hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
> Timecounter "HPET" frequency 14318180 Hz quality 950
> Event timer "HPET" frequency 14318180 Hz quality 550
> Event timer "HPET1" frequency 14318180 Hz quality 450
> Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
> acpi_timer0: <32-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
> pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
> pci0: <ACPI PCI bus> on pcib0
> vgapci0: <VGA-compatible display> port 0xf000-0xf0ff mem
0xc0000000-0xcfffffff,0xfeb00000-0xfeb3ffff irq 18 at device 1.0 on pci0
> pcib1: <ACPI PCI-PCI bridge> irq 16 at device 4.0 on pci0
> pci1: <ACPI PCI bus> on pcib1
> pcib2: <PCI-PCI bridge> irq 16 at device 0.0 on pci1
> pci2: <PCI bus> on pcib2
> em0: <Intel(R) PRO/1000 Legacy Network Connection 1.0.6> port 0xe040-0xe07f mem
0xfea20000-0xfea3ffff,0xfe9c0000-0xfe9fffff irq 16 at device 4.0 on pci2
> em0: Ethernet address: 00:1b:21:a6:31:7c
> em1: <Intel(R) PRO/1000 Legacy Network Connection 1.0.6> port 0xe000-0xe03f mem
0xfea00000-0xfea1ffff,0xfe940000-0xfe97ffff irq 17 at device 4.1 on pci2
> em1: Ethernet address: 00:1b:21:a6:31:7d
> ahci0: <ATI IXP700 AHCI SATA controller> port
0xf190-0xf197,0xf180-0xf183,0xf170-0xf177,0xf160-0xf163,0xf150-0xf15f mem 0xfeb4b000-0xfeb4b3ff irq
19 at device 17.0 on pci0
> ahci0: AHCI v1.20 with 4 6Gbps ports, Port Multiplier supported
> ahcich0: <AHCI channel> at channel 0 on ahci0
> ahcich1: <AHCI channel> at channel 1 on ahci0
> ahcich2: <AHCI channel> at channel 2 on ahci0
> ahcich3: <AHCI channel> at channel 3 on ahci0
> ohci0: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfeb4a000-0xfeb4afff irq 18 at device 18.0 on
pci0
> usbus0 on ohci0
> ehci0: <AMD SB7x0/SB8x0/SB9x0 USB 2.0 controller> mem 0xfeb49000-0xfeb490ff irq 17 at device 18.2
on pci0
> usbus1: EHCI version 1.0
> usbus1 on ehci0
> ohci1: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfeb48000-0xfeb48fff irq 18 at device 19.0 on
pci0
> usbus2 on ohci1
> ehci1: <AMD SB7x0/SB8x0/SB9x0 USB 2.0 controller> mem 0xfeb47000-0xfeb470ff irq 17 at device 19.2
on pci0
> usbus3: EHCI version 1.0
> usbus3 on ehci1
> pci0: <serial bus, SMBus> at device 20.0 (no driver attached)
> atapci0: <ATI IXP700/800 UDMA133 controller> port
0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xf100-0xf10f irq 17 at device 20.1 on pci0
> ata0: <ATA channel> at channel 0 on atapci0
> ata1: <ATA channel> at channel 1 on atapci0
> pci0: <multimedia, HDA> at device 20.2 (no driver attached)
> isab0: <PCI-ISA bridge> at device 20.3 on pci0
> isa0: <ISA bus> on isab0
> pcib3: <ACPI PCI-PCI bridge> at device 20.4 on pci0
> pci3: <ACPI PCI bus> on pcib3
> ohci2: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfeb46000-0xfeb46fff irq 18 at device 20.5 on
pci0
> usbus4 on ohci2
> pcib4: <ACPI PCI-PCI bridge> at device 21.0 on pci0
> pci4: <ACPI PCI bus> on pcib4
> pcib5: <ACPI PCI-PCI bridge> at device 21.1 on pci0
> pci5: <ACPI PCI bus> on pcib5
> re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F/G PCIe Gigabit Ethernet> port 0xd000-0xd0ff mem
0xd0004000-0xd0004fff,0xd0000000-0xd0003fff irq 17 at device 0.0 on pci5
> re0: Using 1 MSI-X message
> re0: Chip rev. 0x48000000
> re0: MAC rev. 0x00000000
> miibus0: <MII bus> on re0
> rgephy0: <RTL8169S/8110S/8211 1000BASE-T media interface> PHY 1 on miibus0
> rgephy0: none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX,
100baseTX-FDX-flow, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow,
1000baseT-FDX-flow-master, auto, auto-flow
> re0: Ethernet address: 30:85:a9:3e:11:69
> ohci3: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfeb45000-0xfeb45fff irq 18 at device 22.0 on
pci0
> usbus5 on ohci3
> ehci2: <AMD SB7x0/SB8x0/SB9x0 USB 2.0 controller> mem 0xfeb44000-0xfeb440ff irq 17 at device 22.2
on pci0
> usbus6: EHCI version 1.0
> usbus6 on ehci2
> acpi_button0: <Power Button> on acpi0
> atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
> atkbd0: <AT Keyboard> irq 1 on atkbdc0
> kbd0 at atkbd0
> atkbd0: [GIANT-LOCKED]
> uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
> amdsbwd0: <AMD SB8xx Watchdog Timer> at iomem 0xfec000f0-0xfec000f3,0xfec000f4-0xfec000f7 on isa0
> sc0: <System console> at flags 0x100 on isa0
> sc0: VGA <16 virtual consoles, flags=0x300>
> vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
> wbwd0: HEFRAS and EFER do not align: EFER 0x2e DevID 0xff DevRev 0xff CR26 0xff
> acpi_throttle0: <ACPI CPU Throttling> on cpu0
> acpi_throttle1: <ACPI CPU Throttling> on cpu1
> acpi_throttle1: failed to attach P_CNT
> device_attach: acpi_throttle1 attach returned 6
> Timecounters tick every 1.000 msec
> ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
> DUMMYNET 0xfffffe0004100c80 with IPv6 initialized (100409)
> load_dn_sched dn_sched RR loaded
> load_dn_sched dn_sched WF2Q+ loaded
> load_dn_sched dn_sched FIFO loaded
> load_dn_sched dn_sched PRIO loaded
> load_dn_sched dn_sched QFQ loaded
> usbus0: 12Mbps Full Speed USB v1.0
> usbus1: 480Mbps High Speed USB v2.0
> usbus2: 12Mbps Full Speed USB v1.0
> usbus3: 480Mbps High Speed USB v2.0
> usbus4: 12Mbps Full Speed USB v1.0
> usbus5: 12Mbps Full Speed USB v1.0
> usbus6: 480Mbps High Speed USB v2.0
> ugen0.1: <ATI> at usbus0
> uhub0: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
> ugen1.1: <ATI> at usbus1
> uhub1: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
> ugen2.1: <ATI> at usbus2
> uhub2: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
> ugen3.1: <ATI> at usbus3
> uhub3: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3
> ugen4.1: <ATI> at usbus4
> uhub4: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus4
> ugen5.1: <ATI> at usbus5
> uhub5: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus5
> ugen6.1: <ATI> at usbus6
> uhub6: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus6
> uhub4: 2 ports with 2 removable, self powered
> uhub5: 4 ports with 4 removable, self powered
> uhub0: 5 ports with 5 removable, self powered
> uhub2: 5 ports with 5 removable, self powered
> uhub6: 4 ports with 4 removable, self powered
> uhub1: 5 ports with 5 removable, self powered
> uhub3: 5 ports with 5 removable, self powered
> ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
> ada0: <V4-CT032V4SSD2 S5FAMM22> ATA-8 SATA 2.x device
> ada0: Serial Number 200068322
> ada0: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
> ada0: Command Queueing enabled
> ada0: 30533MB (62533296 512 byte sectors: 16H 63S/T 16383C)
> ada0: Previously was known as ad4
> ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
> ada1: <TOSHIBA DT01ACA300 MX6OABB0> ATA-8 SATA 3.x device
> ada1: Serial Number X3V9V2YGS
> ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
> ada1: Command Queueing enabled
> ada1: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
> ada1: Previously was known as ad6
> ada2 at ahcich2 bus 0 scbus2 target 0 lun 0
> ada2: <WDC WD30EZRX-00MMMB0 80.00A80> ATA-8 SATA 3.x device
> ada2: Serial Number WD-WCAWZ2248451
> ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
> ada2: Command Queueing enabled
> ada2: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
> ada2: quirks=0x1<4K>
> ada2: Previously was known as ad8
> ada3 at ahcich3 bus 0 scbus3 target 0 lun 0
> ada3: <ST3000DM001-1CH166 CC26> ATA-8 SATA 3.x device
> ada3: Serial Number S1F0SRTZ
> ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
> ada3: Command Queueing enabled
> ada3: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
> ada3: quirks=0x1<4K>
> ada3: Previously was known as ad10
> ada4 at ata0 bus 0 scbus4 target 0 lun 0
> ada4: <WDC WD30EZRX-00MMMB0 80.00A80> ATA-8 SATA 3.x device
> ada4: Serial Number WD-WCAWZ2304085
> ada4: 150.000MB/s transfers (SATA, UDMA6, PIO 8192bytes)
> ada4: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
> ada4: quirks=0x1<4K>
> ada4: Previously was known as ad0
> ada5 at ata0 bus 0 scbus4 target 1 lun 0
> ada5: <WDC WD30EZRX-00D8PB0 80.00A80> ATA-9 SATA 3.x device
> ada5: Serial Number WD-WMC4N2589103
> ada5: 150.000MB/s transfers (SATA, UDMA6, PIO 8192bytes)
> ada5: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
> ada5: quirks=0x1<4K>
> ada5: Previously was known as ad1
> SMP: AP CPU #1 Launched!
> Timecounter "TSC" frequency 1000019340 Hz quality 800
> Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]...
> WARNING: /data was not properly dismounted
> KLD geom_raid5.ko: depends on kernel - not available or version mismatch
> linker_load_file: Unsupported file type
> ZFS filesystem version: 5
> ZFS storage pool version: features support (5000)
> GEOM_ELI: Device ada3p1.eli created.
> GEOM_ELI: Encryption: AES-XTS 256
> GEOM_ELI: Crypto: software
> GEOM_ELI: Device ada4p1.eli created.
> GEOM_ELI: Device ada2p1.eli created.
> GEOM_ELI: Device ada1p1.eli created.
> GEOM_ELI: Device ada5p1.eli created.
> (ada4:ata0:0:0:0): READ_DMA. ACB: c8 00 80 fd 3f 40 00 00 00 00 00 00
> (ada4:ata0:0:0:0): CAM status: ATA Status Error
> (ada4:ata0:0:0:0): ATA status: 51 (DRDY SERV ERR), error: 40 (UNC )
> (ada4:ata0:0:0:0): RES: 51 40 38 fe 3f 00 00 00 00 3f 00
> (ada4:ata0:0:0:0): Retrying command
> (ada4:ata0:0:0:0): Error 5, Retries exhausted
> (ada4:ata0:0:0:0): READ_DMA. ACB: c8 00 80 fe 3f 40 00 00 00 00 00 00
> (ada4:ata0:0:0:0): RES: 51 40 b0 fe 3f 00 00 00 00 cf 00
> GEOM_ELI: g_eli_read_done() failed ada4p1.eli[READ(offset=2147090432, length=131072)]
> GEOM_ELI: g_eli_read_done() failed ada4p1.eli[READ(offset=2147221504, length=131072)]
> (ada1:ahcich1:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 a8 a1 50 40 5d 01 00 00 00 00
> (ada1:ahcich1:0:0:0): CAM status: ATA Status Error
> (ada1:ahcich1:0:0:0): ATA status: 51 (DRDY SERV ERR), error: 10 (IDNF )
> (ada1:ahcich1:0:0:0): RES: 51 10 a8 a1 50 40 5d 01 00 08 00
> (ada1:ahcich1:0:0:0): Retrying command
> Waiting (max 60 seconds) for system process `vnlru' to stop...done
> Waiting (max 60 seconds) for system process `bufdaemon' to stop...done
> Waiting (max 60 seconds) for system process `syncer' to stop...
> Syncing disks, vnodes remaining...0 0 0 done
> All buffers synced.
> GEOM_ELI: Device ada3p1.eli destroyed.
> GEOM_ELI: Detached ada3p1.eli on last close.
> GEOM_ELI: Device ada4p1.eli destroyed.
> GEOM_ELI: Detached ada4p1.eli on last close.
> GEOM_ELI: Device ada2p1.eli destroyed.
> GEOM_ELI: Detached ada2p1.eli on last close.
> GEOM_ELI: Device ada1p1.eli destroyed.
> GEOM_ELI: Detached ada1p1.eli on last close.
> GEOM_ELI: Device ada5p1.eli destroyed.
> GEOM_ELI: Detached ada5p1.eli on last close.
> Uptime: 13m39s
> usbus0: Controller shutdown
> uhub0: at usbus0, port 1, addr 1 (disconnected)
> usbus0: Controller shutdown complete
> usbus1: Controller shutdown
> uhub1: at usbus1, port 1, addr 1 (disconnected)
> usbus1: Controller shutdown complete
> usbus2: Controller shutdown
> uhub2: at usbus2, port 1, addr 1 (disconnected)
> usbus2: Controller shutdown complete
> usbus3: Controller shutdown
> uhub3: at usbus3, port 1, addr 1 (disconnected)
> usbus3: Controller shutdown complete
> usbus4: Controller shutdown
> uhub4: at usbus4, port 1, addr 1 (disconnected)
> usbus4: Controller shutdown complete
> usbus5: Controller shutdown
> uhub5: at usbus5, port 1, addr 1 (disconnected)
> usbus5: Controller shutdown complete
> usbus6: Controller shutdown
amd64
> kbd1 at kbdmux0
pci0
> usbus0 on ohci0
on pci0
> usbus1 on ehci0
pci0
> usbus2 on ohci1
on pci0
> usbus3 on ehci1
pci0
> usbus4 on ohci2
pci0
> usbus5 on ohci3
on pci0
> usbus6 on ehci2
> kbd0 at atkbd0
fracai
That's basically the boot log that gets mailed when you reboot. Are you sure this is happening every night? Same time each night? Do you have the machine scheduled to reboot every night?
krikboh
I doubt anything can be done to speed up the system with an AMD C-60 CPU.
Ames
I had a similar experience of slow writes in freenas 9 (9.2.1.2) as compared to freenas (8.3.1). I'm using CIFS SMB shares, with similar issues copying from Mac or Windows. I noticed that I can't drag and drop a large numbers of photos into a freenas 9 box like I was doing in freenas 8; the copy process would fail. My freenas 9 box (Core(TM) i3-4130 CPU @ 3.40GHz/12Gb RAM), the freenas 8 box (AMD A4-3400 APU with Radeon(tm) HD Graphics@ 2.7GHz/16 Gb RAM). The write performance impact was really noticeable. I've just upgraded to 9.2.1.5 hoping that the write performance is better.
