In order for us to help you with your question we will need the following information to the best of your ability. We do not like to make assumptions here as we might give wrong advice and the next thing you know, your data is gone forever. Please follow the forum rules so that we can offer proper assistance. Below is the rule #3. Provide as much information as possible and don't assume we know exactly how your system is configured.
Including the following information in your thread will increase the chance you will get an answer:
- FreeNAS version and platform (32 or 64 bit).
- General hardware information (CPU, RAM, Motherboard model, etc.).
- Specific hardware information (Network card chipset, Raid controller chipset, etc.).
- DMESG output or copy of specific error message.
- IFCONFIG output if you are asking about a NIC or networking problem.
- PCICONF -lv output if you are asking about MotherBoard and / or PCI card problems.
- Code snippets, logs, config files and quotes should be enclosed in the appropriate bbcode tags.
- To provide you with accurate answers we need this information and it will also help others to find your posts when they are searching for similar information.
[THIS IS A CANNED RESPONSE :p]
Just to let you know, your data is not gone unless you have deleted the pools, a very obvious and deliberate act. As the previous post said, just take a new usb flash drive and pop an image on it, boot it, do an Auto Import, and your files will be there. You will need to set up to share the pool again but that is the easy part.
I added the first part because you had zero information about your system. Thankfully for you the answer was obvious and probably posted in the forums a few thousand times.
8.3 NAS 64bit
CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 6000+
2 GIG RAM
Gigabit Ethernet NIC(NDIS 6.0) (RTL8168/8111/8111c)
ASUS M4A785
DMESG:
Copyright (c) 1992-2012 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 8.3-RELEASE-p6 #0 r248141M: Sun Mar 10 16:35:05 PDT 2013
root@build.ixsystems.com:/home/jpaetzel/8.3.1-RELEASE/os-base/amd64/tank/home/jpaetzel/8.3.1-RELEASE/FreeBSD/src/sys/FREENAS.amd64 amd64
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ (3013.45-MHz K8-class CPU)
Origin = "AuthenticAMD" Id = 0x40f33 Family = f Model = 43 Stepping = 3
Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
Features2=0x2001<SSE3,CX16>
AMD Features=0xea500800<SYSCALL,NX,MMX+,FFXSR,RDTSCP,LM,3DNow!+,3DNow!>
AMD Features2=0x1f<LAHF,CMP,SVM,ExtAPIC,CR8>
real memory = 2147483648 (2048 MB)
avail memory = 1792229376 (1709 MB)
ACPI APIC Table: <041410 APIC1753>
FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s)
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ACPI Warning: Optional field Pm2ControlBlock has zero address or length: 0x0000000000000000/0x1 (20101013/tbfadt-655)
ioapic0 <Version 2.1> irqs 0-23 on motherboard
kbd1 at kbdmux0
hpt27xx: RocketRAID 27xx controller driver v1.0 (Mar 10 2013 16:34:54)
cryptosoft0: <software crypto> on motherboard
aesni0: No AESNI support.
acpi0: <041410 XSDT1753> on motherboard
acpi0: [ITHREAD]
acpi0: Power Button (fixed)
acpi0: reservation of fee00000, 1000 (3) failed
acpi0: reservation of ffb80000, 80000 (3) failed
acpi0: reservation of fec10000, 20 (3) failed
acpi0: reservation of fed40000, 5000 (3) failed
acpi0: reservation of 0, a0000 (3) failed
acpi0: reservation of 100000, 6ff00000 (3) failed
Timecounter "ACPI-safe" frequency 3579545 Hz quality 850
acpi_timer0: <32-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 900
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
vgapci0: <VGA-compatible display> port 0xd000-0xd0ff mem 0xd0000000-0xdfffffff,0xfeaf0000-0xfeafffff,0xfe900000-0xfe9fffff irq 18 at device 5.0 on pci1
pci1: <multimedia, HDA> at device 5.1 (no driver attached)
pcib2: <ACPI PCI-PCI bridge> irq 18 at device 10.0 on pci0
pci2: <ACPI PCI bus> on pcib2
re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F PCIe Gigabit Ethernet> port 0xe800-0xe8ff mem 0xfdfff000-0xfdffffff,0xfdff8000-0xfdffbfff irq 18 at device 0.0 on pci2
re0: Using 1 MSI-X message
re0: Chip rev. 0x28000000
re0: MAC rev. 0x00000000
miibus0: <MII bus> on re0
rgephy0: <RTL8169S/8110S/8211B media interface> PHY 1 on miibus0
rgephy0: none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
re0: Ethernet address: 90:e6:ba:88:30:28
re0: [ITHREAD]
ahci0: <ATI IXP700 AHCI SATA controller> port 0xc000-0xc007,0xb000-0xb003,0xa000-0xa007,0x9000-0x9003,0x8000-0x800f mem 0xfe8ffc00-0xfe8fffff irq 22 at device 17.0 on pci0
ahci0: [ITHREAD]
ahci0: AHCI v1.10 with 4 3Gbps ports, Port Multiplier supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich0: [ITHREAD]
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich1: [ITHREAD]
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich2: [ITHREAD]
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich3: [ITHREAD]
ohci0: <OHCI (generic) USB controller> mem 0xfe8fe000-0xfe8fefff irq 16 at device 18.0 on pci0
ohci0: [ITHREAD]
usbus0: <OHCI (generic) USB controller> on ohci0
ohci1: <OHCI (generic) USB controller> mem 0xfe8fd000-0xfe8fdfff irq 16 at device 18.1 on pci0
ohci1: [ITHREAD]
usbus1: <OHCI (generic) USB controller> on ohci1
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfe8ff800-0xfe8ff8ff irq 17 at device 18.2 on pci0
ehci0: [ITHREAD]
usbus2: EHCI version 1.0
usbus2: <EHCI (generic) USB 2.0 controller> on ehci0
ohci2: <OHCI (generic) USB controller> mem 0xfe8fc000-0xfe8fcfff irq 18 at device 19.0 on pci0
ohci2: [ITHREAD]
usbus3: <OHCI (generic) USB controller> on ohci2
ohci3: <OHCI (generic) USB controller> mem 0xfe8fb000-0xfe8fbfff irq 18 at device 19.1 on pci0
ohci3: [ITHREAD]
usbus4: <OHCI (generic) USB controller> on ohci3
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xfe8ff400-0xfe8ff4ff irq 19 at device 19.2 on pci0
ehci1: [ITHREAD]
usbus5: EHCI version 1.0
usbus5: <EHCI (generic) USB 2.0 controller> on ehci1
pci0: <serial bus, SMBus> at device 20.0 (no driver attached)
atapci0: <ATI IXP700/800 UDMA133 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xff00-0xff0f at device 20.1 on pci0
ata0: <ATA channel> at channel 0 on atapci0
ata0: [ITHREAD]
ata1: <ATA channel> at channel 1 on atapci0
ata1: [ITHREAD]
pci0: <multimedia, HDA> at device 20.2 (no driver attached)
isab0: <PCI-ISA bridge> at device 20.3 on pci0
isa0: <ISA bus> on isab0
pcib3: <ACPI PCI-PCI bridge> at device 20.4 on pci0
pci3: <ACPI PCI bus> on pcib3
ohci4: <OHCI (generic) USB controller> mem 0xfe8fa000-0xfe8fafff irq 18 at device 20.5 on pci0
ohci4: [ITHREAD]
usbus6: <OHCI (generic) USB controller> on ohci4
amdtemp0: <AMD K8 Thermal Sensors> on hostb4
acpi_button0: <Power Button> on acpi0
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
ppc0: <Parallel port> port 0x378-0x37f irq 7 on acpi0
ppc0: Generic chipset (NIBBLE-only) in COMPATIBLE mode
ppc0: [ITHREAD]
ppbus0: <Parallel port bus> on ppc0
lpt0: <Printer> on ppbus0
lpt0: [ITHREAD]
lpt0: Interrupt-driven port
acpi_hpet1: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
device_attach: acpi_hpet1 attach returned 12
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbd0: [ITHREAD]
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart0: [FILTER]
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
acpi_throttle0: <ACPI CPU Throttling> on cpu0
powernow0: <PowerNow! K8> on cpu0
powernow1: <PowerNow! K8> on cpu1
fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Timecounters tick every 1.000 msec
hpt27xx: no controller detected.
GEOM_RAID5: Module loaded, version 1.1.20110927.40 (rev 00ce00e5abb4)usbus0: 12Mbps Full Speed USB v1.0
usbus1: 12Mbps Full Speed USB v1.0
usbus2: 480Mbps High Speed USB v2.0
usbus3: 12Mbps Full Speed USB v1.0
usbus4: 12Mbps Full Speed USB v1.0
usbus5: 480Mbps High Speed USB v2.0
usbus6: 12Mbps Full Speed USB v1.0
ugen0.1: <ATI> at usbus0
uhub0: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <ATI> at usbus1
uhub1: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
ugen2.1: <ATI> at usbus2
uhub2: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus2
ugen3.1: <ATI> at usbus3
uhub3: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus3
ugen4.1: <ATI> at usbus4
uhub4: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus4
ugen5.1: <ATI> at usbus5
uhub5: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus5
ugen6.1: <ATI> at usbus6
uhub6: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus6
uhub6: 2 ports with 2 removable, self powered
uhub0: 3 ports with 3 removable, self powered
uhub1: 3 ports with 3 removable, self powered
uhub3: 3 ports with 3 removable, self powered
uhub4: 3 ports with 3 removable, self powered
uhub2: 6 ports with 6 removable, self powered
uhub5: 6 ports with 6 removable, self powered
ugen2.2: <vendor 0x13fe> at usbus2
umass0: <vendor 0x13fe Patriot Memory, class 0/0, rev 2.00/1.00, addr 2> on usbus2
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <HDS722525VLSA80 V36OA6MA> ATA-6 SATA 1.x device
ada0: 150.000MB/s transfers (SATA 1.x, UDMA5, PIO 8192bytes)
ada0: 238475MB (488397168 512 byte sectors: 16H 63S/T 16383C)
ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: <HDS722525VLSA80 V36OA6MA> ATA-6 SATA 1.x device
ada1: 150.000MB/s transfers (SATA 1.x, UDMA5, PIO 8192bytes)
ada1: 238475MB (488397168 512 byte sectors: 16H 63S/T 16383C)
ada2 at ahcich2 bus 0 scbus2 target 0 lun 0
ada2: <HDS722525VLSA80 V36OA6MA> ATA-6 SATA 1.x device
ada2: 150.000MB/s transfers (SATA 1.x, UDMA5, PIO 8192bytes)
ada2: 238475MB (488397168 512 byte sectors: 16H 63S/T 16383C)
ada3 at ahcich3 bus 0 scbus3 target 0 lun 0
ada3: <HDS722525VLSA80 V36OA6MA> ATA-6 SATA 1.x device
ada3: 150.000MB/s transfers (SATA 1.x, UDMA5, PIO 8192bytes)
ada3: 238475MB (488397168 512 byte sectors: 16H 63S/T 16383C)
ada4 at ata0 bus 0 scbus4 target 0 lun 0
ada4: <WDC WD3200JB-00KFA0 08.05J08> ATA-6 device
ada4: 100.000MB/s transfers (UDMA5, PIO 8192bytes)
ada4: 305245MB (625142448 512 byte sectors: 16H 63S/T 16383C)
ada5 at ata1 bus 0 scbus5 target 0 lun 0
ada5: <HDS722525VLSA80 V36OA6MA> ATA-6 SATA 1.x device
ada5: 150.000MB/s transfers (SATA, UDMA5, PIO 8192bytes)
ada5: 238475MB (488397168 512 byte sectors: 16H 63S/T 16383C)
ada6 at ata1 bus 0 scbus5 target 1 lun 0
ada6: <HDS722525VLSA80 V36OA6MA> ATA-6 SATA 1.x device
ada6: 150.000MB/s transfers (SATA, UDMA5, PIO 8192bytes)
ada6: 238475MB (488397168 512 byte sectors: 16H 63S/T 16383C)
cd0 at ata0 bus 0 scbus4 target 1 lun 0
cd0: <ATAPI DVD W DH16W1P LG12> Removable CD-ROM SCSI-0 device SMP: AP CPU #1 Launched!
cd0: 66.700MB/s transfers
(UDMA4, ATAPI 12bytes, PIO 65534bytes)
cd0: Attempt to query device size failed: NOT READY, Medium not present
da0 at umass-sim0 bus 0 scbus6 target 0 lun 0
da0: < Patriot Memory PMAP> Removable Direct Access SCSI-0 device
da0: 40.000MB/s transfers
da0: 1910MB (3911680 512 byte sectors: 255H 63S/T 243C)
GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
ZFS NOTICE: Prefetch is disabled by default if less than 4GB of RAM is present;
to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
ZFS filesystem version 5
ZFS storage pool version 28
GEOM_ELI: Device ada0p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI: Crypto: software
GEOM_ELI: Device ada1p1.eli created.
GEOM_ELI: Device ada2p1.eli created.
GEOM_ELI: Device ada3p1.eli created.
GEOM_ELI: Device ada5p1.eli created.
GEOM_ELI: Device ada6p1.eli created.
IFCONFIG:
re0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC>
ether 90:e6:ba:88:30:28
inet 192.168.1.88 netmask 0xffffff00 broadcast 192.168.1.255
media: Ethernet autoselect (100baseTX <full-duplex>)
status: active
options=3<RXCSUM,TXCSUM>
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x9
inet6 ::1 prefixlen 128
nd6 options=3<PERFORMNUD,ACCEPT_RTADV>
PCICONF
hostb0@pci0:0:0:0: class=0x060000 card=0x83a21043 chip=0x96011022 rev=0x00 hdr=0x00
vendor = 'Advanced Micro Devices (AMD)'
class = bridge
subclass = HOST-PCI
pcib1@pci0:0:1:0: class=0x060400 card=0x83a21043 chip=0x96021043 rev=0x00 hdr=0x01
vendor = 'Asustek Computer Inc.'
class = bridge
subclass = PCI-PCI
pcib2@pci0:0:10:0: class=0x060400 card=0x83a21043 chip=0x96091022 rev=0x00 hdr=0x01
class = bridge
subclass = PCI-PCI
ahci0@pci0:0:17:0: class=0x01018f card=0x83891043 chip=0x43901002 rev=0x00 hdr=0x00
vendor = 'ATI Technologies Inc. / Advanced Micro Devices, Inc.'
device = 'Integrated SATA II Controller (SB700)'
class = mass storage
subclass = ATA
ohci0@pci0:0:18:0: class=0x0c0310 card=0x83891043 chip=0x43971002 rev=0x00 hdr=0x00
device = 'SB700 USB OHCI0 Controller'
class = serial bus
subclass = USB
ohci1@pci0:0:18:1: class=0x0c0310 card=0x83891043 chip=0x43981002 rev=0x00 hdr=0x00
device = 'Standard OpenHCD USB-Hostcontroller (SB700)'
class = serial bus
subclass = USB
ehci0@pci0:0:18:2: class=0x0c0320 card=0x83891043 chip=0x43961002 rev=0x00 hdr=0x00
device = 'SB700 USB EHCI Controller'
class = serial bus
subclass = USB
ohci2@pci0:0:19:0: class=0x0c0310 card=0x83891043 chip=0x43971002 rev=0x00 hdr=0x00
class = serial bus
subclass = USB
ohci3@pci0:0:19:1: class=0x0c0310 card=0x83891043 chip=0x43981002 rev=0x00 hdr=0x00
class = serial bus
subclass = USB
ehci1@pci0:0:19:2: class=0x0c0320 card=0x83891043 chip=0x43961002 rev=0x00 hdr=0x00
class = serial bus
subclass = USB
none0@pci0:0:20:0: class=0x0c0500 card=0x83891043 chip=0x43851002 rev=0x3c hdr=0x00
device = 'ATI SMBus (ATI RD600/RS600)'
class = serial bus
subclass = SMBus
atapci0@pci0:0:20:1: class=0x01018a card=0x83891043 chip=0x439c1002 rev=0x00 hdr=0x00
device = 'PATA 133 Controller (SB7xx)'
subclass = ATA
none1@pci0:0:20:2: class=0x040300 card=0x836c1043 chip=0x43831002 rev=0x00 hdr=0x00
device = 'IXP SB600 High Definition Audio Controller'
class = multimedia
subclass = HDA
isab0@pci0:0:20:3: class=0x060100 card=0x83891043 chip=0x439d1002 rev=0x00 hdr=0x00
device = 'SB700 LPC host controller'
class = bridge
subclass = PCI-ISA
pcib3@pci0:0:20:4: class=0x060401 card=0x00000000 chip=0x43841002 rev=0x00 hdr=0x01
device = 'IXP SB600 PCI to PCI Bridge'
class = bridge
subclass = PCI-PCI
ohci4@pci0:0:20:5: class=0x0c0310 card=0x83891043 chip=0x43991002 rev=0x00 hdr=0x00
device = 'SB700 USB OHCI2 Controller'
class = serial bus
subclass = USB
hostb1@pci0:0:24:0: class=0x060000 card=0x00000000 chip=0x11001022 rev=0x00 hdr=0x00
device = 'Athlon64/Opteron/Sempron (K8 Family) HyperTransport Technology Configuration'
class = bridge
subclass = HOST-PCI
hostb2@pci0:0:24:1: class=0x060000 card=0x00000000 chip=0x11011022 rev=0x00 hdr=0x00
device = 'Athlon64/Opteron/Sempron (K8 Family) Address Map'
class = bridge
subclass = HOST-PCI
hostb3@pci0:0:24:2: class=0x060000 card=0x00000000 chip=0x11021022 rev=0x00 hdr=0x00
device = 'Athlon64/Opteron/Sempron (K8 Family) DRAM Controller'
class = bridge
subclass = HOST-PCI
hostb4@pci0:0:24:3: class=0x060000 card=0x00000000 chip=0x11031022 rev=0x00 hdr=0x00
device = 'Athlon64/Opteron/Sempron (K8 Family) Miscellaneous Control'
class = bridge
subclass = HOST-PCI
vgapci0@pci0:1:5:0: class=0x030000 card=0x83a21043 chip=0x97101002 rev=0x00 hdr=0x00
device = 'ATI Radeon HD 4200 (RS880)'
class = display
subclass = VGA
none2@pci0:1:5:1: class=0x040300 card=0x83a21043 chip=0x970f1002 rev=0x00 hdr=0x00
class = multimedia
subclass = HDA
re0@pci0:2:0:0: class=0x020000 card=0x83a31043 chip=0x816810ec rev=0x03 hdr=0x00
vendor = 'Realtek Semiconductor'
device = 'Gigabit Ethernet NIC(NDIS 6.0) (RTL8168/8111/8111c)'
class = network
subclass = ethernet
