Factory Reset
kiwinz123
Hi I am pretty new to Freenas and all, could some quickly clarify the below for me.
Basically I made a mistake of setting a WebGUI Port but it doesnt work and I am now locked out of the webgui which is bad as i have set it up so my company can access files in all their offices. Basically I was told that a factory reset would do the trick, but does this wipe all the data you have stored on the hard drives??
Sorry for such a Noob question!
kiwinz123
Brilliant thanks, do you happen to know if that will reset the WebGui URL and get rid of the WebGUI Port setting?
warri
Yes, the port will be reset.
