Hardware Description.....
# dmidecode 2.11
SMBIOS version fixup (2.33 -> 2.3).
SMBIOS 2.3 present.
43 structures occupying 1400 bytes.
Table at 0xBFF79000.
Handle 0x0000, DMI type 0, 20 bytes
BIOS Information
Vendor: Phoenix Technologies LTD
Version: 6.00
Release Date: 08/21/2006
Address: 0xE45A0
Runtime Size: 113248 bytes
ROM Size: 1024 kB
Characteristics:
ISA is supported
PCI is supported
PNP is supported
BIOS is upgradeable
BIOS shadowing is allowed
ESCD support is available
Boot from CD is supported
Selectable boot is supported
EDD is supported
3.5"/2.88 MB floppy services are supported (int 13h)
ACPI is supported
USB legacy is supported
LS-120 boot is supported
ATAPI Zip drive boot is supported
BIOS boot specification is supported
Handle 0x0001, DMI type 1, 25 bytes
System Information
Manufacturer: Supermicro
Product Name: X6DH8
Version: 0123456789
Serial Number: 0123456789
UUID: 80F1E964-DC63-0010-89D5-0030486908D2
Wake-up Type: Power Switch
Handle 0x0002, DMI type 2, 8 bytes
Base Board Information
Product Name: X6DH8
Version: PCB Version
Handle 0x0003, DMI type 3, 17 bytes
Chassis Information
Type: Other
Lock: Not Present
Version: 0123456789
Asset Tag:
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00001234
Handle 0x0004, DMI type 4, 35 bytes
Processor Information
Socket Designation: CPU1
Type: Central Processor
Family: Pentium 4
Manufacturer: GenuineIntel
ID: 4A 0F 00 00 FF FB EB BF
Signature: Type 0, Family 15, Model 4, Stepping 10
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
DS (Debug store)
ACPI (ACPI supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
SS (Self-snoop)
HTT (Multi-threading)
TM (Thermal monitor supported)
PBE (Pending break enabled)
Version: Intel(R) Xeon(TM) CPU 3.00GHz
Voltage: 1.4 V
External Clock: 200 MHz
Max Speed: 4000 MHz
Current Speed: 3000 MHz
Status: Populated, Enabled
Upgrade: Other
L1 Cache Handle: 0x0006
L2 Cache Handle: 0x0007
L3 Cache Handle: Not Provided
Serial Number: Not Specified
Asset Tag: Not Specified
Part Number: Not Specified
Handle 0x0005, DMI type 4, 35 bytes
Socket Designation: CPU2
Family: Pentium 4
Flags:
DS (Debug store)
SS (Self-snoop)
Voltage: 1.4 V
Max Speed: 4000 MHz
Upgrade: Other
L1 Cache Handle: 0x0008
L2 Cache Handle: 0x0009
Handle 0x0006, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1 Cache
Configuration: Enabled, Socketed, Level 1
Operational Mode: Write Back
Installed Size: 16 kB
Maximum Size: 16 kB
Supported SRAM Types:
Burst
Pipeline Burst
Asynchronous
Installed SRAM Type: Asynchronous
Speed: Unknown
Error Correction Type: Unknown
System Type: Unknown
Associativity: Unknown
Handle 0x0007, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2 Cache
Configuration: Enabled, Socketed, Level 2
Installed Size: 2048 kB
Maximum Size: 1024 kB
Burst
Pipeline Burst
Asynchronous
Installed SRAM Type: Burst
Speed: Unknown
Handle 0x0008, DMI type 7, 19 bytes
Cache Information
Maximum Size: 16 kB
Burst
Pipeline Burst
Asynchronous
Speed: Unknown
Handle 0x0009, DMI type 7, 19 bytes
Cache Information
Burst
Pipeline Burst
Asynchronous
Speed: Unknown
Handle 0x000A, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: J6
Internal Connector Type: 9 Pin Dual Inline (pin 10 cut)
External Reference Designator: COM1
External Connector Type: DB-9 male
Port Type: Serial Port 16550A Compatible
Handle 0x000B, DMI type 8, 9 bytes
Internal Reference Designator: J7
External Reference Designator: COM2
Handle 0x000C, DMI type 8, 9 bytes
Internal Reference Designator: J23
Internal Connector Type: 25 Pin Dual Inline (pin 26 cut)
External Reference Designator: PRINTER
External Connector Type: DB-25 female
Port Type: Parallel Port ECP/EPP
Handle 0x000D, DMI type 8, 9 bytes
Internal Reference Designator: J9
Internal Connector Type: None
External Reference Designator: Keyboard
External Connector Type: Circular DIN-8 male
Port Type: Keyboard Port
Handle 0x000E, DMI type 8, 9 bytes
External Reference Designator: PS/2 Mouse
Handle 0x000F, DMI type 9, 13 bytes
System Slot Information
Designation: PCIX#1-100MHz
Type: 64-bit PCI-X
Current Usage: Available
Length: Long
Characteristics:
3.3 V is provided
Handle 0x0010, DMI type 9, 13 bytes
Designation: PCIX#2-100MHz
Type: 64-bit PCI-X
Length: Long
Characteristics:
3.3 V is provided
Handle 0x0011, DMI type 9, 13 bytes
Designation: PCIX#3-133MHz
Type: 64-bit PCI-X
Current Usage: In Use
Length: Long
Characteristics:
3.3 V is provided
Handle 0x0012, DMI type 9, 13 bytes
Designation: PCIE#4-x4
Type: Other
Length: Other
Characteristics:
3.3 V is provided
Handle 0x0013, DMI type 9, 13 bytes
Designation: PCIE#5-x8
Type: Other
Length: Other
Characteristics:
3.3 V is provided
Handle 0x0014, DMI type 9, 13 bytes
Designation: PCIE#6-x8
Type: Other
Length: Other
Characteristics:
3.3 V is provided
Handle 0x0015, DMI type 11, 5 bytes
OEM Strings
String 1: Intel Nocona/TumWater/ICH5R
String 2: Supermicro motherboard X6DH8
Handle 0x0016, DMI type 12, 5 bytes
System Configuration Options
Option 1: Jumper settings can be described here.
Handle 0x0017, DMI type 15, 29 bytes
System Event Log
Area Length: 288 bytes
Header Start Offset: 0x0000
Header Length: 16 bytes
Data Start Offset: 0x0010
Access Method: General-purpose non-volatile data functions
Access Address: 0x0000
Status: Valid, Not Full
Change Token: 0x000000D1
Header Format: Type 1
Supported Log Type Descriptors: 3
Descriptor 1: POST error
Data Format 1: POST results bitmap
Descriptor 2: Single-bit ECC memory error
Data Format 2: Multiple-event
Descriptor 3: Multi-bit ECC memory error
Data Format 3: Multiple-event
Handle 0x0018, DMI type 16, 15 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: Single-bit ECC
Maximum Capacity: 16 GB
Error Information Handle: Not Provided
Number Of Devices: 4
Handle 0x0019, DMI type 17, 27 bytes
Memory Device
Array Handle: 0x0018
Error Information Handle: No Error
Total Width: 72 bits
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM#1A
Bank Locator: Bank 1
Type: DDR
Type Detail: Synchronous
Speed: 400 MHz
Manufacturer: Not Specified
Handle 0x001A, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM#2A
Bank Locator: Bank 2
Type: DDR
Speed: 400 MHz
Handle 0x001B, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM#3A
Bank Locator: Bank 3
Type: DDR
Speed: 400 MHz
Handle 0x001C, DMI type 17, 27 bytes
Memory Device
Total Width: Unknown
Data Width: Unknown
Size: No Module Installed
Form Factor: DIMM
Set: 1
Locator: DIMM#4A
Bank Locator: Bank 4
Type: DDR
Speed: 400 MHz
Handle 0x001D, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM#1B
Type: DDR
Speed: 400 MHz
Handle 0x001E, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM#2B
Type: DDR
Speed: 400 MHz
Handle 0x001F, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM#3B
Type: DDR
Speed: 400 MHz
Handle 0x0020, DMI type 17, 27 bytes
Memory Device
Data Width: Unknown
Form Factor: DIMM
Set: 1
Locator: DIMM#4B
Type: DDR
Speed: 400 MHz
Handle 0x0021, DMI type 19, 15 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x0027FFFFFFF
Range Size: 10 GB
Physical Array Handle: 0x0018
Partition Width: 1
Handle 0x0022, DMI type 20, 19 bytes
Memory Device Mapped Address
Ending Address: 0x0007FFFFFFF
Range Size: 2 GB
Physical Device Handle: 0x0019
Memory Array Mapped Address Handle: 0x0021
Partition Row Position: Unknown
Interleave Position: Unknown
Interleaved Data Depth: Unknown
Handle 0x0023, DMI type 23, 13 bytes
System Reset
Status: Enabled
Watchdog Timer: Present
Boot Option: Do Not Reboot
Boot Option On Limit: Do Not Reboot
Reset Count: Unknown
Reset Limit: Unknown
Timer Interval: Unknown
Timeout: Unknown
Handle 0x0024, DMI type 24, 5 bytes
Hardware Security
Power-On Password Status: Disabled
Keyboard Password Status: Unknown
Administrator Password Status: Enabled
Front Panel Reset Status: Unknown
Handle 0x0025, DMI type 30, 6 bytes
Out-of-band Remote Access
Manufacturer Name: Intel
Inbound Connection: Enabled
Outbound Connection: Disabled
Handle 0x0026, DMI type 32, 20 bytes
System Boot Information
Status: <OUT OF SPEC>
Handle 0x0027, DMI type 38, 18 bytes
IPMI Device Information
Interface Type: Unknown
Specification Version: 0.0
I2C Slave Address: 0x00
NV Storage Device Address: 0
Base Address: 0x0000000000000000 (Memory-mapped)
Register Spacing: Successive Byte Boundaries
Interrupt Polarity: Active Low
Interrupt Trigger Mode: Edge
Handle 0x0028, DMI type 126, 4 bytes
Inactive
Handle 0x0029, DMI type 127, 4 bytes
End Of Table
Handle 0x002A, DMI type 127, 4 bytes
End Of Table
