Help : disk offline-unavailable-removed !!!???
dom239
Since several days/months, (and probably after having switch to FreeNAS-9.2.0-RELEASE-x64 ab098f4), I got some checksum errors for one then two disks.
I checked according :
[root@freenas] ~# zdb -C | grep ashift
ashift: 9
So I know I am with 512B block size, but even if I am loosing some performance, for now I cannot change all the disks.
Because of the checksum errors, I changed the disks according the 'right' procedure. (By the way : the dismounted disks were checked with CrystaDiskInfo under windows and appeared 'correct').
BUT the problems arised again, again change the disks, and then worse I could never get the new disk ON Line. I mean the 'Replace Disk' button did not show any disk availaible (no Member disk to choose).
Whatever I try I had either OFFLINE, or UNAVAIL and even REMOVED !.
Now I am lost.
Could anybody can tell me :
1) what could be the cause of not having a new disk appearing as a member to choose ?
2) how can I get the new disks On Line ?
3) any idea of what I can/should do ?
Thanks a lot
Dominique
FreeNAS-9.2.0-RELEASE-x64 (ab098f4) Intel(R) Pentium(R) CPU G620 @ 2.60GHz 16050MB
[root@freenas] ~# zpool status
pool: POOL1
state: DEGRADED
status: One or more devices could not be opened. Sufficient replicas exist for
the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
see: http://illumos.org/msg/ZFS-8000-2Q
scan: resilvered 1.13M in 146h25m with 0 errors on Fri Mar 14 21:02:16 2014
NAME STATE READ WRITE CKSUM
POOL1 DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
gptid/d0b92dc8-2c0d-11e2-94e9-bc5ff445822a ONLINE 0 0 0 block size: 512B configured, 4096B native
gptid/d13dd130-2c0d-11e2-94e9-bc5ff445822a ONLINE 0 0 0 block size: 512B configured, 4096B native
13425672597925114130 UNAVAIL 0 0 0 was /dev/gptid/603f24bd-76eb-11e3-9b51-bc5ff445822a
13487041251522937133 UNAVAIL 0 0 0 was /dev/gptid/d209fdde-2c0d-11e2-94e9-bc5ff445822a
gptid/d2746b47-2c0d-11e2-94e9-bc5ff445822a ONLINE 0 0 0 block size: 512B configured, 4096B native
gptid/d2d7484e-2c0d-11e2-94e9-bc5ff445822a ONLINE 0 0 0 block size: 512B configured, 4096B native
gptid/68383b3f-c06c-11e2-82a9-bc5ff445822a ONLINE 0 0 0 block size: 512B configured, 4096B native
gptid/d4005e4d-2c0d-11e2-94e9-bc5ff445822a ONLINE 0 0 0 block size: 512B configured, 4096B native
gptid/d474cb79-2c0d-11e2-94e9-bc5ff445822a ONLINE 0 0 0 block size: 512B configured, 4096B native
gptid/d4cd7159-2c0d-11e2-94e9-bc5ff445822a ONLINE 0 0 0 block size: 512B configured, 4096B native
errors: No known data errors
YOu using the same sata ports the allegedly failed but apparently good disks were using? It's possible those ports are broken now...
In any case, you have no redundancy left on your pool, so I'd be replacing that disk ASAP or shutting down the system. All you need is a flaky disk right now and your pool will be done for. I hope you have backups...
dom239
Thanks a lot cyberjock for your very fast answer.
These 2 disk are connected to a 4 ports PCI SATAII 150-300 Promise . I already change the ports, but same thing. I may have a spare card !... . I will change it as soon as possible. I know I have no redundancy so the NAS is shutdown for now.
Thanks
Dominique
