Since several days/months, (and probably after having switch to FreeNAS-9.2.0-RELEASE-x64 ab098f4), I got some checksum errors for one then two disks.
I checked according :
[root@freenas] ~# zdb -C | grep ashift
ashift: 9
So I know I am with 512B block size, but even if I am loosing some performance, for now I cannot change all the disks.
Because of the checksum errors, I changed the disks according the 'right' procedure. (By the way : the dismounted disks were checked with CrystaDiskInfo under windows and appeared 'correct').
BUT the problems arised again, again change the disks, and then worse I could never get the new disk ON Line. I mean the 'Replace Disk' button did not show any disk availaible (no Member disk to choose).
Whatever I try I had either OFFLINE, or UNAVAIL and even REMOVED !.
Now I am lost.
Could anybody can tell me :
1) what could be the cause of not having a new disk appearing as a member to choose ?
2) how can I get the new disks On Line ?
3) any idea of what I can/should do ?
Thanks a lot
Dominique
FreeNAS-9.2.0-RELEASE-x64 (ab098f4) Intel(R) Pentium(R) CPU G620 @ 2.60GHz 16050MB
[root@freenas] ~# zpool status
pool: POOL1
state: DEGRADED
status: One or more devices could not be opened. Sufficient replicas exist for
the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
see: http://illumos.org/msg/ZFS-8000-2Q
scan: resilvered 1.13M in 146h25m with 0 errors on Fri Mar 14 21:02:16 2014
NAME STATE READ WRITE CKSUM
POOL1 DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
gptid/d0b92dc8-2c0d-11e2-94e9-bc5ff445822a ONLINE 0 0 0 block size: 512B configured, 4096B native
gptid/d13dd130-2c0d-11e2-94e9-bc5ff445822a ONLINE 0 0 0 block size: 512B configured, 4096B native
13425672597925114130 UNAVAIL 0 0 0 was /dev/gptid/603f24bd-76eb-11e3-9b51-bc5ff445822a
13487041251522937133 UNAVAIL 0 0 0 was /dev/gptid/d209fdde-2c0d-11e2-94e9-bc5ff445822a
gptid/d2746b47-2c0d-11e2-94e9-bc5ff445822a ONLINE 0 0 0 block size: 512B configured, 4096B native
gptid/d2d7484e-2c0d-11e2-94e9-bc5ff445822a ONLINE 0 0 0 block size: 512B configured, 4096B native
gptid/68383b3f-c06c-11e2-82a9-bc5ff445822a ONLINE 0 0 0 block size: 512B configured, 4096B native
gptid/d4005e4d-2c0d-11e2-94e9-bc5ff445822a ONLINE 0 0 0 block size: 512B configured, 4096B native
gptid/d474cb79-2c0d-11e2-94e9-bc5ff445822a ONLINE 0 0 0 block size: 512B configured, 4096B native
gptid/d4cd7159-2c0d-11e2-94e9-bc5ff445822a ONLINE 0 0 0 block size: 512B configured, 4096B native
errors: No known data errors
ashift: 9
Now I am lost.
Thanks a lot
Dominique
pool: POOL1
state: DEGRADED
