itsryan
 - Jan 11, 2017
Im trying to solve a problem on my main PC, when I try to connect to my server from my pc i get a connection refused error message. I have SMB setup and for this test i turned on SSH. SMB and SSH can not be accessed from my main PC as well.
I am able to connect to the server from other devices on the same network, SMB, SSH and direct connection all work from multiply devices but not my main PC.
If I restart the server it fixes the problem for a short time but the problem comes back after a few days. I have seen a few posts talking about it might be a middlewared problem and restarting they could fix it but it does not work in my case. I have also changed my ip to see if its ip locked, no luck on that either.
What it feels like is my login session does not expire and it locks me out after a while. I have searched for a way to reset the session logins without restarting but no luck.
Can anyone help me solve this problem.
TrueNAS-12.0-U4
If you need more info please let me know.
TrueNAS-12.0-U4
