Help connecting applications to shares or datasets
C0sm0
I am sure that this must be posted somewhere in this community but I could not find the relevant thread.
I am new to Truenas and have just installed TrueNAS-SCALE-22.02.0.1.
I have added the truecharts catalog since I want to install airsonic/booksonic emby and other media applications.
The installations seem top go fine and the applications appear in the installed applications.
My issue is that in the applications, I cannot see how to use the datasets or shares I created for the media storage.
Mapping to them or searching for then seems to be a problem here.
I was hoping someone could point me to a tutorial on the permissions required to be applied here.
Very much appreciate any help someone can give me.
Thank you
C0sm0
LarsR
you have to add a hostpath to link the datasets outside the container to a folder inside the container
for Plex it could be something like "/mnt/Movies" as the path where your movies are stored to "/media" inside the plex container.
C0sm0
you have to add a hostpath to link the datasets outside the container to a folder inside the container for Plex it could be something like "/mnt/Movies" as the path where your movies are stored to "/media" inside the plex container.
I will try that, thank you :smile:
