Welcome to the forums!
Read the resources section, FreeNAS should not be run on hardware RAID so there will
be an adjustment of how your drives interface with the OS.
I started 4-1/2 years ago with an old consumer board and used two drives to form a simple mirrored pool. The GUI was fairly easy but the CLI was a mystery to me back then. My advice is to get your hands dirty and learn to set up SMART testing and how to recover a failed/failing drive. It's good to learn early on how to break it and recover so that when IT happens, you will be
prepared when the inevitable happens.
Be prepared to spend time reading through the resources section AND of course the well documented Users Guide.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
