Shifty One
- May 5, 2016
As the title says... I have having a heck of a time getting ix0/ix1 10GBit working here. I had it working, forgot what I did, upgraded ram, rebooted... and lost my changes. I "think" that I used ifconfig to force some NIC settings.... I did not document this... After I upgraded from 32 to 64GB, I am back to 100MBits.
I have tried hard setting the interface to 10GB on both Switch and interface. Doesnt help. `history` seems to be lost between sessions so I cant see what I did.
ifconfig output:
I have a Ubiquity Aggregate 8-port 10GB switch. I am using (or tried) both Copper 10GB SFP+ devices, Models QSFPTEK QT-SFP-10G-T and 10Gtek ASF-10G-T. The QSFPEK claim to be compatible with Ubiquity but the 10Gtek are listed as compatible with Ubiquity (on their page). I have had both SFPs workign with other Intel NICs and Free/TrueNAS.
Switch currently thinks the port is in 10GB mode:
Status 10,000 FDX
Part: SFP-10G-SR
Compliance: 10G Base-SR
TrueNAS thinks otherwise... Media Subtype: 100baseTX
In the past, I "think" i used ifconfig to force it to 10GB... Obviously this did not persist past a reboot.
NIC Details:
Motherboard/CPU: (Memory: 4 16GB sticks, all the same part number)
ifconfig output:
ix0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: connected to 10GB-Agg (Port 3)
options=e53fbb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_UCAST,WOL_MCAST,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
ether d0:50:99:dd:59:d7
inet 10.1.150.22 netmask 0xffffff00 broadcast 10.1.150.255
media: Ethernet autoselect (100baseTX <full-duplex>)
status: active
Status 10,000 FDX
Part: SFP-10G-SR
NIC Details:
ix0@pci0:65:0:0: class=0x020000 card=0x15631849 chip=0x15638086 rev=0x01 hdr=0x00
vendor = 'Intel Corporation'
device = 'Ethernet Controller 10G X550T'
class = network
subclass = ethernet
ix1@pci0:65:0:1: class=0x020000 card=0x15631849 chip=0x15638086 rev=0x01 hdr=0x00
class = network
subclass = ethernet
Base Board Information
Manufacturer: ASRockRack
Product Name: EPYCD8-2T
Processor Information
Socket Designation: CPU1
Type: Central Processor
Family: Zen
Manufacturer: Advanced Micro Devices, Inc.
Version: AMD EPYC 7252 8-Core Processor
Voltage: 1.1 V
External Clock: 100 MHz
Max Speed: 3200 MHz
Current Speed: 3100 MHz
Status: Populated, Enabled
Upgrade: Socket SP3
Memory Device
Array Handle: 0x0023
Error Information Handle: 0x002D
Total Width: 72 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM 0
Bank Locator: P0 CHANNEL B
Type: DDR4
Type Detail: Synchronous Registered (Buffered)
Speed: 2666 MT/s
Manufacturer: SK Hynix
Serial Number: REDACTED
Asset Tag: Not Specified
Part Number: HMA82GR7AFR8N-VK
Rank: 2
Configured Memory Speed: 2666 MT/s
Minimum Voltage: 1.2 V
Maximum Voltage: 1.2 V
Configured Voltage: 1.2 V
