Hi, I'm not sure, but I think this issue arose in one of the last updates, since I hadn't noticed it before. I have some of my HDDs (which are on a rarely used pool) set to the following:
so the disks should spin down after being idle for 120 minutes, but they spin down after being idle after a couple minutes instead. I tried to change the APM settings to others allowing spindown/standby (L 64, L 127), but this didn't fix the issue. Also changing the time to something higher didn't seem to fix it.
I check if disks are up by issuing
Anybody any idea what might be going on or how to debug this? I am running TrueNAS-SCALE-22.02.3
Disk Type: HDD Transfer Mode: Auto HDD Standby: 120 Adv. Power Management: 1 Enable S.M.A.R.T.: true S.M.A.R.T. extra options:
hdparm -C /dev/sde
, and they return "standby" a couple mins after I copied something to the pool.Anybody any idea what might be going on or how to debug this? I am running TrueNAS-SCALE-22.02.3
