I'm quite new to FreeNAS and still learning/tweaking my first system.  I've been trying the HDD Standby settings but am not seeing the results I'd expect.
To diagnose what's going on, I've run the following test:
1) Of my four disks, set each to a different standby time from the gui: 5, 10, 30 60.
For all, APM and Accoustic disabled, smart enabled.
2) Reboot
3) Run a script (from this thread http://forums.freenas.org/showthread.php?2068-How-to-find-out-if-a-drive-is-spinning-down-properly) that prints every 30s whether each drive is in stanby or spinning. I've put the script in /tmp and redirect the output to /tmp/results. Running nohup in the backgroup.
4) Access the drives to 'reset' any standby timer
5) Wait a couple of hours then check results.
What I find is that the first two drives both go to sleep after 10 minutes:
Two hours later and the state is the same.
So standby time to results mapping is:
5 = standby after 10
10 = standby after 10
30 = never standby
60 = never standby
My first question is whether FreeNAS is setting the ataidle settings correctly. Is this command logged in a logfile somewhere? Output on startup?
If it is being set correctly, is it the drives not supporting all the different sleep times? They're 2TB WD Green.
Reason I want standby is I'd like to leave the FreeNAS 24/7 and I'll only access it evenings and weekend and then only infrequently (so could go days weeks without access). I'd prefer to save some power and some wear and tear. With my usage I'd have thought spin down after 30 mins or 60 mins would be a good idea.
My specs:
Here's camcontrol identify for the first drive (others should all be the same):
BTW anyone know what 'power-up in Standby' is? I guess I should probably see if the firmware is up to date, but I'm reluctant to as I think it requires windows to update.
Thanks in advacne to anyone who can point me in the direction of some useful info or provide any assistance.
2) Reboot
time: 20:42:32 pass0: SPINNING pass1: SPINNING pass2: SPINNING pass3: SPINNING ... time: 20:51:32 pass0: IDLE pass1: IDLE pass2: SPINNING pass3: SPINNING
30 = never standby
60 = never standby
My specs:
- FreeNAS 8.3
 - HP ProLiant Microserver N40
 - 4x 2TB WD Green HDD in RaidZ1 with single volume/dataset
 - 8GB RAM
 - PowerD not enabled in advanced settings
pass0: <WDC WD20EARX-00PASB0 51.0AB51> ATA-8 SATA 3.x device pass0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) protocol ATA/ATAPI-8 SATA 3.x device model WDC WD20EARX-00PASB0 firmware revision 51.0AB51 serial number WD-WCAZAF516841 WWN 50014ee25c883c98 cylinders 16383 heads 16 sectors/track 63 sector size logical 512, physical 4096, offset 0 LBA supported 268435455 sectors LBA48 supported 3907029168 sectors PIO supported PIO4 DMA supported WDMA2 UDMA6 Feature Support Enabled Value Vendor read ahead yes yes write cache yes yes flush cache yes yes overlap no Tagged Command Queuing (TCQ) no no Native Command Queuing (NCQ) yes 32 tags SMART yes yes microcode download yes yes security yes no power management yes yes advanced power management no no automatic acoustic management no no media status notification no no power-up in Standby yes no write-read-verify no no unload no no free-fall no no data set management (TRIM) no
