Any reason you think I stripe wouldn't work when a mirror, RAIDZx, or single disk would? I'm not seeing why your pool architecture would have any affect on hdd standby or APM setting...
They'll both be woken up by virtually any read or write to the pool. Regardless of your pool design, you can usually expect that any read or write to the pool will wake up the entire pool.
The system is running in an office which operates roughly 9am to 5pm. It is used for backups which are done throughout the day, but after 6pm there is probably no usgae of the FreeNAS system at all (all computers switched off). What would you recommend for the 'HDD Standby' or 'Advanced Power Management' settings? I was thinking...
I don't recommend sleeping disks at all. Sleeping disks requires no activity on the pool(which often doesn't happen when people think it would) and the act of spinning up the disks excessively seems to shorten their lifespan.
Really depends on use.. I don't think you have any redundancy with 2 drives striped.. If they get 1 daily backup and never do anything else I'd consider spinning it down..
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
