hssfreenas
- May 15, 2018
Hallo,
habe auf meinem mirror eine defekte HDD und bekomme folgende Fehlermeldungen:
meine FreeNAS-Version ist aktuell, die 11.1-U4 (FreeBSD 11.1-STABLE (FreeNAS.amd64) #2 r321665+366f54a78b2(freenas/11.1-stable))...
smartctl -a /dev/ada0 sagt folgendes:
- KRITISCH: 14. Mai 2018 10:10 - Device: /dev/ada0, 35 Currently unreadable (pending) sectors
- KRITISCH: 14. Mai 2018 10:41 - Device: /dev/ada0, new Self-Test Log error at hour timestamp 37594
root@FreeNAS:~ # smartctl -a /dev/ada0 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Black Device Model: WDC WD3003FZEX-00Z4SA0 Serial Number: WD-WCC1XXXXXXXX LU WWN Device Id: 5 0014ee 7aae047dc Firmware Version: 01.01A01 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Wed May 16 21:53:02 2018 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x84) Offline data collection activity was suspended by an interrupting command from host. Auto Offline Data Collection: Enabled. Self-test execution status: ( 121) The previous self-test completed having the read element of the test failed. Total time to complete Offline data collection: (30480) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 331) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x7035) SCT Status supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 199 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 157 143 021 Pre-fail Always - 11116 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 41 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 049 049 000 Old_age Always - 37653 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 39 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 17 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 25 194 Temperature_Celsius 0x0022 105 091 000 Old_age Always - 47 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 34 198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed: read failure 90% 37644 38351104 # 2 Short offline Completed: read failure 90% 37632 38351064 # 3 Short offline Completed: read failure 90% 37620 38351064 # 4 Short offline Completed: read failure 90% 37608 38351064 # 5 Extended offline Completed: read failure 90% 37599 38351064 # 6 Short offline Completed: read failure 90% 37596 38351064 # 7 Extended offline Completed: read failure 90% 37594 38351064 # 8 Short offline Completed: read failure 90% 37584 38351064 # 9 Short offline Completed: read failure 90% 37572 38351064 #10 Short offline Completed: read failure 90% 37560 38351064 #11 Short offline Completed: read failure 90% 37548 38351064 #12 Short offline Completed: read failure 90% 37536 38351064 #13 Short offline Completed: read failure 90% 37524 38351064 #14 Short offline Completed: read failure 10% 37512 38371992 #15 Short offline Completed: read failure 90% 37500 38351064 #16 Short offline Completed: read failure 90% 37488 38357160 #17 Short offline Completed: read failure 90% 37476 38357160 #18 Short offline Completed: read failure 90% 37464 38357160 #19 Short offline Completed: read failure 90% 37452 38357160 #20 Short offline Completed: read failure 10% 37440 38375160 #21 Short offline Completed without error 00% 37428 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
