HDD failure...replace with ? (is WD Red+ standard still?)
I built my server several years ago and used WD 3TB Red drives (4 drives).
A couple failed a year or so ago. Now another one has an unreadable sector.
I was about to buy another WD 3TB Red+...but figured I would check in.
Is there a new "standard" for HDD to use in these NAS systems? I think at a price/TB WD was the best.
But, does that still hold up? Should I be changing to another manufacturer at this point? Or the (+) is still good for a home NAS?
Jailer
Not strong, but bad
Just make sure whatever you get that it's a CMR drive and not a SMR drive.
Morris
If you wish to stay with those slow and power efficient WD Red drives, then you must get the WD Red Plus as they have changed the naming. I WD Red will not work well in TrueNAS. The Plus model is CMR which is a requirement.
