HBA help
Scrat_
Got one you'd recommend since my board doesn't seem to recognize my drives?
SATA to SFF-8087 on backplane.
Sent from my SM-N950W using Tapatalk
Doesn't the hardware recommendations guide address this? Any LSI/Broadcom/Avago 2008/2308/3008-based controller should do the job.
Scrat_
Since FreeNAS likes direct access to drives, the card needs JBOD mode, yes?
Chris Moore
No. That is a hardware RAID card, NOT an HBA.
You need one like this:
Drive Controller: LSI-SAS-9211-8i-8-port-6Gb-s-PCI-E-Internal-HBA-Both-Brackets-IT-MODE - US $59.99
https://www.ebay.com/itm/152937435505
Drive Cables: Mini SAS to 4-SATA SFF-8087 Multi-Lane Forward Breakout Internal Cable - - US $12.99
https://www.ebay.com/itm/371681252206
Only, you may not need the forward breakout. Did you have the SFF-8087 on the drive side also?
How many drive backplanes? Where is you build log?
