MachineShedFred
- May 31, 2011
Hello.
First, thank you for creating this wonderful software.
Second, here's my problem: I recently upgraded to FreeNAS 8 from 0.7.2 by doing a clean install onto a new CF card, and imported my ZFS pool. I then configured the shares and off we go.
However, it panics when I try to play video off the NAS after a minute or two.
I'm using two Supermicro AOC-SAT2-MV8 PCI-X cards to connect my drives. They use the Marvell Hercules-II Rev. C0 SATA controller, and are both plugged into the PCI-X bus on the motherboard. I've been able to reproduce this issue at a rate of 100%.
However, when I move one of the MV8 boards to a different PCI bus (this motherboard has three, one 32-bit / 33Mhz; one 64-bit / 66Mhz; and the 64-bit / 133Mhz PCI-X) it works just as it should. However, one of the controllers will have half the bandwidth of the other since the bus it's plugged into is signalled at half the rate.
Is there an issue with Marvell Hercules-II drivers on FreeBSD 8, where it doesn't like two controllers on the same PCI bus ID? I'd love to be able to get both of them back to full bandwidth, as I was getting close to the theoretical gigabit ethernet throughput between my FreeNAS 0.7.2 box and my Mac Pro before the upgrade :D
I'll put the cards back and grab the full error from the console. Thanks!
