Have 2 disk with errors in Raidz2. which one should be chang first?
GolDenis
Have 2 HDD for exchange, but.... I should start with ada2 or ada3.
Definitely don't want to change 2 HDD for one step.
ada2:
root@freenas[~]# smartctl -x /dev/ada2
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Green
Device Model:     WDC WD30EZRX-00MMMB0
Serial Number:    WD-WCAWZ2290028
LU WWN Device Id: 5 0014ee 25c5e9345
Firmware Version: 80.00A80
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Fri Dec  6 23:26:58 2019 +07
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
Self-test execution status:      ( 121) The previous self-test completed having
                                        the read element of the test failed.
data collection:                (49380) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 475) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x3035) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    0
  3 Spin_Up_Time            POS--K   143   137   021    -    9816
  4 Start_Stop_Count        -O--CK   057   057   000    -    43182
  5 Reallocated_Sector_Ct   PO--CK   200   200   140    -    0
  7 Seek_Error_Rate         -OSR-K   200   200   000    -    0
  9 Power_On_Hours          -O--CK   015   015   000    -    62559
 10 Spin_Retry_Count        -O--CK   100   100   000    -    0
 11 Calibration_Retry_Count -O--CK   100   100   000    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    209
192 Power-Off_Retract_Count -O--CK   200   200   000    -    121
193 Load_Cycle_Count        -O--CK   183   183   000    -    51545
194 Temperature_Celsius     -O---K   112   092   000    -    40
196 Reallocated_Event_Count -O--CK   200   200   000    -    0
197 Current_Pending_Sector  -O--CK   200   198   000    -    110
198 Offline_Uncorrectable   ----CK   200   198   000    -    106
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    0
200 Multi_Zone_Error_Rate   ---R--   200   001   000    -    114
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      6  Ext. Comprehensive SMART error log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa0-0xa7  GPL,SL  VS      16  Device vendor specific log
0xa8-0xb7  GPL,SL  VS       1  Device vendor specific log
0xbd       GPL,SL  VS       1  Device vendor specific log
0xc0       GPL,SL  VS       1  Device vendor specific log
0xc1       GPL     VS      93  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 1
        CR     = Command Register
        FEATR  = Features Register
        COUNT  = Count (was: Sector Count) Register
        LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
        LH     = LBA High (was: Cylinder High) Register    ]   LBA
        LM     = LBA Mid (was: Cylinder Low) Register      ] Register
        LL     = LBA Low (was: Sector Number) Register     ]
        DV     = Device (was: Device/Head) Register
        DC     = Device Control Register
        ER     = Error register
        ST     = Status register
Error 1 [0] occurred at disk power-on lifetime: 47280 hours (1970 days + 0 hours)
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  40 -- 51 00 00 00 01 2f 9e d6 28 40 00  Error: UNC at LBA = 0x12f9ed628 = 5093905960
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  60 01 00 00 90 00 01 2f 9e de 00 40 08     23:00:39.210  READ FPDMA QUEUED
  60 01 00 00 48 00 01 2f 9e dd 00 40 08     23:00:39.210  READ FPDMA QUEUED
  60 00 08 00 08 00 01 2f 9e dc f8 40 08     23:00:39.208  READ FPDMA QUEUED
  60 00 80 00 18 00 01 2f 9e dc 78 40 08     23:00:39.207  READ FPDMA QUEUED
  60 00 78 00 40 00 01 2f 9e dc 00 40 08     23:00:39.207  READ FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Short offline       Completed: read failure       90%     62545         2847728902
# 2  Short offline       Completed without error       00%     62522         -
# 3  Short offline       Completed without error       00%     61787         -
# 4  Short offline       Completed without error       00%     61049         -
# 5  Short offline       Completed without error       00%     60306         -
# 6  Short offline       Completed without error       00%     59587         -
# 7  Short offline       Completed without error       00%     58844         -
# 8  Short offline       Completed without error       00%     58034         -
# 9  Short offline       Completed without error       00%     57305         -
SCT Status Version:                  3
SCT Version (vendor specific):       258 (0x0102)
SCT Support Level:                   1
Device State:                        Active (0)
Current Temperature:                    40 Celsius
Power Cycle Min/Max Temperature:     36/46 Celsius
Lifetime    Min/Max Temperature:      0/60 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/60 Celsius
Min/Max Temperature Limit:           -41/85 Celsius
Temperature History Size (Index):    478 (343)
or ada3:
root@freenas[~]# smartctl -x /dev/ada3
Serial Number:    WD-WCAWZ2948621
LU WWN Device Id: 5 0014ee 25cade5b9
User Capacity:    3,000,591,900,160 bytes [3.00 TB]
Local Time is:    Fri Dec  6 23:35:15 2019 +07
data collection:                (49680) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 477) minutes.
  3 Spin_Up_Time            POS--K   146   145   021    -    9691
  4 Start_Stop_Count        -O--CK   097   097   000    -    3233
  9 Power_On_Hours          -O--CK   029   029   000    -    51969
 12 Power_Cycle_Count       -O--CK   100   100   000    -    241
192 Power-Off_Retract_Count -O--CK   200   200   000    -    187
193 Load_Cycle_Count        -O--CK   001   001   000    -    1968887
194 Temperature_Celsius     -O---K   112   099   000    -    40
197 Current_Pending_Sector  -O--CK   200   200   000    -    166
198 Offline_Uncorrectable   ----CK   200   200   000    -    166
199 UDMA_CRC_Error_Count    -O--CK   200   149   000    -    1766
200 Multi_Zone_Error_Rate   ---R--   200   200   000    -    177
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
Device Error Count: 5
        ER     = Error register
Error 5 [4] occurred at disk power-on lifetime: 51874 hours (2161 days + 10 hours)
  40 -- 51 00 00 00 00 e9 1b 15 00 40 00  Error: UNC at LBA = 0xe91b1500 = 3910866176
  60 00 c0 00 b0 00 00 e9 1b 15 70 40 08  5d+09:28:52.337  READ FPDMA QUEUED
  60 01 00 00 a8 00 00 e9 1b 14 70 40 08  5d+09:28:52.337  READ FPDMA QUEUED
  2f 00 00 00 01 00 00 00 00 00 10 40 08  5d+09:28:52.337  READ LOG EXT
  60 00 30 00 98 00 00 04 fa ab 88 40 08  5d+09:28:49.685  READ FPDMA QUEUED
  60 00 30 00 90 00 00 04 fa ab 50 40 08  5d+09:28:49.685  READ FPDMA QUEUED
Error 4 [3] occurred at disk power-on lifetime: 51874 hours (2161 days + 10 hours)
  60 00 c0 00 88 00 00 e9 1b 15 70 40 08  5d+09:28:49.685  READ FPDMA QUEUED
  60 01 00 00 80 00 00 e9 1b 14 70 40 08  5d+09:28:49.684  READ FPDMA QUEUED
  2f 00 00 00 01 00 00 00 00 00 10 40 08  5d+09:28:49.684  READ LOG EXT
Error 3 [2] occurred at disk power-on lifetime: 51874 hours (2161 days + 10 hours)
  60 00 30 00 60 00 00 04 fa aa e8 40 08  5d+09:28:47.065  READ FPDMA QUEUED
  60 00 c0 00 58 00 00 e9 1b 15 70 40 08  5d+09:28:47.065  READ FPDMA QUEUED
  60 01 00 00 50 00 00 e9 1b 14 70 40 08  5d+09:28:47.065  READ FPDMA QUEUED
  2f 00 00 00 01 00 00 00 00 00 10 40 08  5d+09:28:47.065  READ LOG EXT
  60 00 30 00 38 00 00 04 fa aa b0 40 08  5d+09:28:44.412  READ FPDMA QUEUED
Error 2 [1] occurred at disk power-on lifetime: 51874 hours (2161 days + 10 hours)
  60 00 c0 00 30 00 00 e9 1b 15 70 40 08  5d+09:28:44.412  READ FPDMA QUEUED
  60 01 00 00 28 00 00 e9 1b 14 70 40 08  5d+09:28:44.412  READ FPDMA QUEUED
  2f 00 00 00 01 00 00 00 00 00 10 40 08  5d+09:28:44.412  READ LOG EXT
  60 00 c0 00 10 00 00 e9 1b 15 70 40 08  5d+09:28:41.735  READ FPDMA QUEUED
Error 1 [0] occurred at disk power-on lifetime: 51874 hours (2161 days + 10 hours)
  60 01 00 00 08 00 00 e9 1b 14 70 40 08  5d+09:28:41.735  READ FPDMA QUEUED
  60 00 10 00 00 00 00 e9 1b 14 58 40 08  5d+09:28:41.724  READ FPDMA QUEUED
  60 00 28 00 f8 00 00 e9 1b 14 28 40 08  5d+09:28:41.722  READ FPDMA QUEUED
  60 00 18 00 f0 00 00 e9 1b 14 10 40 08  5d+09:28:41.722  READ FPDMA QUEUED
# 1  Short offline       Completed: read failure       90%     51955         3908325112
# 2  Short offline       Completed without error       00%     51932         -
Power Cycle Min/Max Temperature:     35/46 Celsius
Lifetime    Min/Max Temperature:      0/53 Celsius
Temperature History Size (Index):    478 (169)
I will appreciate any suggestion
Jailer
Not strong, but bad
Start with ada3.
Jessep
Might want to think about improving cooling, 40c at idle is a bit high, would likely hit 45-50c+ during rebuild/scrub.
GolDenis
Thanks. I will waite for a new fan. But.... I'm in Thailand now... so... +28-30 its a normal temperature in the room.
and I think a high temperature is a symptom. Other disks are a little bit colder. not too much but -3/5 degree.
Chris Moore
Failure rate will be higher when the drives are hot. More fans / more airflow is called for. Good luck.
Chris Moore
PS. Looking at the power on hours of those drives, if they are all around the same age, you might want to start planning to rotate in some younger drives. Frequency of failure tends to increase when the drives are over 5 years of age and those are both pushing the limit.
Start with ada3.
Concur. Both are bad, but ada3 is worse. And when you get replacements, make sure to set the load cycle timer to something sensible, as excessive load cycles will also cause failures. And make sure you have regular short and long SMART tests scheduled for all your disks.
GolDenis
Thanks a lot.
Last question.
Should I make Long test/Scrub Tasks BEFORE or AFTER disk replacement?
GolDenis
Ok... waiting for the new cooler... & change disks one-by-one with final tests after final exchange.
Thanks, guys...
GolDenis
Replace !st disk (ada3)
Get that picture:
Question
When I should change the 2nd disk?
I'm confusing with "Status: SCANNING"
Should I wait to change the status/finish scanning?
GolDenis
aha . The problem became dipper, then I thought
After rebooting disk was returned into the pool....
But...After scanning completed - removed again
Checking status of zfs pools:
NAME           SIZE  ALLOC   FREE  CKPOINT  EXPANDSZ   FRAG    CAP  DEDUP  HEALTH  ALTROOT
AudioVideo    16.2T  6.98T  9.27T        -         -     2%    42%  1.00x  DEGRADED  /mnt
Backups       16.2T  6.73T  9.52T        -         -     1%    41%  1.00x  ONLINE  /mnt
freenas-boot   111G  1.64G   109G        -         -      -     1%  1.00x  ONLINE  -
  pool: AudioVideo
state: DEGRADED
status: One or more devices is currently being resilvered.  The pool will
    continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
  scan: resilver in progress since Thu Dec 12 23:12:50 2019
    5.46T scanned at 418M/s, 5.26T issued at 403M/s, 6.98T total
    43.0G resilvered, 75.37% done, 0 days 01:14:32 to go
    AudioVideo                                      DEGRADED     4     0     0
      raidz1-0                                      DEGRADED     4     0     0
        gptid/bbb27d4e-0d64-11ea-9324-0cc47aabf316  ONLINE       4     0     0
        5749026980364468559                         REMOVED      0     0     0  was /dev/gptid/e2f52d6b-1cc5-11ea-923a-0cc47aabf316
        gptid/c1cfb2ad-0d64-11ea-9324-0cc47aabf316  ONLINE       0     0     0
        gptid/c48694cf-0d64-11ea-9324-0cc47aabf316  ONLINE       0     0     0
        gptid/c7c21b4c-0d64-11ea-9324-0cc47aabf316  ONLINE       0     0     0
        gptid/ccf0d828-0d64-11ea-9324-0cc47aabf316  ONLINE       0     0     0
errors: 3 data errors, use '-v' for a list
-- End of daily output --
reboot again...
Disk returned to the pool...
Scanning... disk removed out of the pool
That's a NEW disk.
How can I stop it and return the disk to the pool?
  • secoutput.txt
