DataKeeper
- Feb 19, 2015
3 more questions...
1. Regarding the M1015 controller.. While starting with 12 drives though eventually running 24 total should I run with a single M1015 card or should it be split between two?
2. Is the performance hit really that great if only a single pair is used rather then 4 modules? I'll be going with the Samsung 16GB RDIMMs and yes, this IS due to cost of the project!
Price just dropped $10 bucks each. I'm going to order 2 modules for 32GB for now during the install and testing.
3. I've ignored ZIL and L2ARC entirely and honestly haven't read up on either that much aside from they can affect the systems performance both negatively and positively depending on build and use. I don't see the system being hit hard that often in all truth. Should I bother with either or these two options or not? Can they be added at a later date it eventually needed?
I'll more then likely purchase the single port 10GbE X540-T1 network card. Mainboard has 2 on-board gigabyte ports which can be used if wanted.
I've updated initial post with sources and current pricing as of today for most hardware.
Thanks for all the support and comments so far!
