I'm the guy that wrote this post about using USB with Freenas...
https://forums.freenas.org/index.php?threads/do-not-attempt-to-use-freenas-with-usb.39175/
Anyway, in my quest to avoid using vanilla sata in a case so I could have blinky lights to help me figure out which drive was dead when one died I have now replaced my 8 USB 3.0 docking stations with ....
http://www.newegg.com/Product/Produ...cm_re=4_bay_esata_dock-_-17-576-013-_-Product
and
http://www.newegg.com/Product/Produ...=mediasonic_esata_card-_-16-322-010-_-Product
And so far its working like a champ. HOWEVER the docking stations have port multipliers, and ironically right before I bought them I read an article about how when you use esata port multipliers that when you lose one drive in the device that is using port multipliers that all the drives on the device will drop and naturally it happened to me immediately. In FreeNAS it showed one of my 1.5TB seagate drives failed a smart test because of reallocated sectors and it told me to back up now, but the entire volume that drive was in dropped. Now the nice part was that all I had to do was reboot and the volume showed right back up again. I removed the drive, put a new one in, resilvered (I resilver like a BOSS now I have had so much practice) and it was good to go. So the setup works great, but I would only use it for like a home system or something. If a drive goes bad you won't lose the whole volume, it will just be offline until you reboot. You'll know which drive went bad though from the messages in FreeNAS. So for the price, for a home system where being offline for a short while is no big deal, the setup works great.
And no, I WILL NOT just use regular sata! I need my blinky lights. =/
and
