aztekgold
- Apr 5, 2015
Looking to start my first FreeNAS build and need some help on hardware choices ,
I want something for file backup on upto 3PC's, basic iTunes server and 1080p streaming to upto to one main TV.
I want it to be reasonably cheap as it is my first FreeNas build and want to get my footing. I also want it as low power as possible.
Motherboard
looking at a asrock Q2900M (quad pentium 2.4ghz) or Q1900M (quad celeron 2.0ghz) see comparison
comes with onboard CPU with a passive heatsink really saving on power.
Power Supply
When it comes to power supplies i never buy anything other that corsair for the reliability so will probably pick up a CX430M trusty budget power supply. I have a spare RM700 watt but would be a bit overkill in a 2 - 5 bay nas??
Memory
probably go with a trusty set of 8 - 16gb of Kingston ram.
Case
Fractal Design 304 looks like a solid choice, although I do have a spare Corsair obsidian 250d case which is the perfect size but is really lacking the Hard Drive Space (2 x 3.5inch and 2 x ssd size), if any modifications can be made to support more drives in the 250d that would save some money.
Hard Drives
2 x 2TB
WD Reds seem like a no-brainer, I have had a look at the Seagate NAS drives but they are a bit pricey.
Any ideas?
Motherboard
Power Supply
Memory
Case
Hard Drives
2 x 2TB
Any ideas?
