Hardware failure due to overheating, cannot recover pool
iliak
We had a cooling problem in our server room last night and one of the servers (unfortunately storage server suffered )
the error:
this is a freenas data disk and cannot boot system
I tried to play with bios settings but no luck, both OS drives (Intel raid mirror) are recognized in the Intel raid option (shows upon boot),
i tried to upgrade\reinstall freenas (via iso disk), it recognized the old installed freenas (11.2-7 i think) and upgraded successfully to 11.3-u4.1
but after reboot i still have the same prompt of "this is a freenas data disk and cannot boot system"
any idea?
Redcoat
Sounds like the BIOS boot settings are not correct, or the "Intel raid mirror" is interfering with the boot process somehow. I have had a few experiences of needed to adjust AMI BIOS settings including removing any reference to non-bootable drives from the boot-order list to limit the potential for it to attempt to use them...
Good luck with working through this.
iliak
After some playing around (disabled raid and boot drive directly)
i got this error
iliak
Update:
i was able to install the the os and recover one pool (can recover with import or with load config (i had a copy for this scenario )
But the second pool (the important one) is dead (it was based on 8 drives on raidz3 ),
it is shown as unknown
is it possible somehow to rebuild it (without formatting the drives) and recover the data ? it hosted some lxc containers,
