gpsguy
Active Member
 - Jan 22, 2012
IANAN (I am not a Noob), but I've been away from FreeNAS (serious health issues in the family) for ~5 months and between RTFM, my search terms, memory - I can't find the answers I need.
Last winter I built a server running FN 8.0.4 x64 server [home use] with a 2Tb (2x2Tb) ZFS mirror. I was slowly moving (consolidating data from multiple pc's/server's) to it. And, at the same time, backing it up to multiple hard disks. Sometime in the June/July/August timeframe, I started having issues with my hardware. I'm sure I documented the problem at the time, but can't find it now. I could boot, by it the server would crash shortly thereafter. Booting off my backup USB drive yielded the same issue, even after I reinstalled the OS on it. So, it looked like a hardware issue of some sort. Now (December), I can't even get the system to POST with a FN USB Flash drive in the server. My guess is that my full backups (3+) contain between 90-100% of the source data, but I can't compare them with the original. I was rotating between backups, as I loaded the data, so I wouldn't have all my eggs in one basket.
Rather than trying to diagnose and fix my current system, I took advantage of the Black Friday/Cyber Monday specials here in the US, and bought a HP Microserver (n40l) and 8Gb of RAM. I'll put an Intel Pro/1000 NIC in it. I know the server doesn't have much horsepower, but at this point, all I want to do is synchronize my source data with my backups. Then figure out where I want to go with FN.
So, where do I go from here? I have a fairly simple installation - 2 users, 3 CIFS shares, and good notes on the installation. I also have multiple backups of my freenas*.db configuration file.
Should I format a USB stick with 8.3.0 or 8.0.4? Should I put both drives in the new machine (if they are mirrored, shouldn't one be enough?, in case something goes sour). Is the backup config (freenas*.db) any good (with new hardware).
TIA, Bill
TIA, Bill
