We're going to repurpose our current production SAN (running Nexenta) into a FreeNas server used for backup storage (disk images via scp, rsyncs of millions of files). We have this hardware available:
2 x Xeon Dual CPU servers, 96GB memory, dual 10GB NIC in each.
2 x STEC ZEUS 8GB SSDs for ZIL
2 x OCZ Talos 460GB for L2 ARC
2 x LSI 9200-8e SAS HBA
2 x DataON 1600D SAS 24 Bay JBODs with dual SIMs (controllers?) (manual: https://goo.gl/ycEjtA)
Right now we're in an active/passive setup using Nexenta, we will be using just one server for FreeNas, so i'll put as much memory from the other server into the one unit. Redundancy isn't a worry, be it server failure, HBA failure or JBOD failure, i'm not too concerned.
We will have 24 x 4TB SAS disks, in mirrored vdev pairs.
My question is regarding performance of SAS bandwidth. Specifically:
Thanks,
Elliot
- Is it best to put the ZIL and L2 ARC in the server rather than the JBOD to use internal HBA bandwidth, or perhaps on their own dedicated HBA / PCIe Slot?
- Should i look at using 2 x JBODS and splitting mirrored vdevs between them to increase bandwidth? or;
- Can i use multiple SAS HBAs connecting to the single JBOD to increase overall SAS bandwidth?
- What is the SAS bandwidth between the HBA and the JBODs, is it 6gbps per port? Or more?
Thanks,
Elliot
