CookiesLikeWhoa
- Mar 22, 2016
First off let me say thank you ahead of time! I've been reading the forum for the past month and think I have finally grasped enough to start planning something. I'm not the most gifted when it comes to hardware, and even less so with most software so bare with me!
The ultimate goal of the build:
Back up solution for 2 work stations, and my family's random computers.
File server
Plex (media) Server (transcoding will be required, 4 ipads, 3 rokus, etc.)
Possibly storing VM's, but that would be down the road.
I work a lot with Photoshop, Lightroom and Premier, while my better half works with Maya (extensively) and some Solidworks for reference.
CPU: Xeon 1650 V3 (alternatively the 1620 V3 was my first option but further reading suggested the transacoding might benefit from the 2 extra cores)
Ram: 4x 16GB ECC Reg Hynix: HMA42GR7MFR4N-TF (expanding to 8 later for 128 gigs)
Mobo: Supermicro X10SRL-F or X10SRH-CF (recommendation requested)
Case: Case Labs M8A
PSU: EVGA 750 G2
HDD: 8x WD Red 4TB (Expanding later)
SSD: 8x Samsung 250 Evo's (for current projects only, backed up to the main pool often)
Boot Drive: Samsung 32gb Flash Drive or other recommendations.
HBA Card: Recommendations welcome. I have an IBM m1015/LSI 9240-8i, which seems to be the go to card and flash it to IT mode. Though I see that the X10SRH-CF has the 8 SAS ports on the LSI 3008 chip. Reading was sparse about this and mostly from late 2014 to mid 2015, and there wasn't much support for it. Has anything changed since then?
The main pool will be set up in a "raid 10" style with mirrored vdevs (4x), if I read the presentation correctly.
Hopefully all looks good, but any advice would be greatly appreciated! I want to do this right.
File server
Case: Case Labs M8A
PSU: EVGA 750 G2
