Hello FreeNAS forum users
I have been scouring these boards for almost a year now, limping along with an old repurposed gaming box, planning my next build. I believe I have my final build list (ignore pool configuration, as they will be changing). If possible, take a look at the build list and make recommendations. Unless I hear back that my configuration has any flaws, I will be purchasing the following hardware:
MB: Super Micro X10SRL-F
CPU: Intel Xeon E5-1620 v3
RAM: Samsung 64GB DDR4-2133 (M393A4K40BB0-CPB)
BOOT: 32GB SATADOM (DESMV-32GD06RC1QCF)
POOL1: 4 x 2TB WD Red RAIDZ2
POOL2: 6 x 4TB WD Red RAIDZ2
PSU: SeaSonic Platinum 860W (SS-860XP2)
CASE: Nanoxia Deep Silence 6
I considered the X10SRH-CF, but decided the SAS3 was not a good idea, and money would be better spent on a dedicated SAS2 controller (to be added later). Also, I realize the 860W power supply may be a bit overkill, for my immediate needs... I like to oversize and buy things once, and since I "can" eventually fit 20+ drives in this case, I want to have enough power.
Please let me know your thoughts, especially if you have direct experience with the X10SR* board and E5-1620v3... For example, I found examples that the E5-1620v3 DOES NOT officially support LRDIMM memory, even though it is listed as compatible. Therefore, I'm going with 32GB sticks of RDIMM, to eventually max out at 256GB.
Cheers!
Cheers!
