NewbieOnTour
- Jul 16, 2012
Hello community!
I am planning on buying all these equipments and would be happy to know, if the setup is compatible with FreeNAS 8 and if it is a good choice in general:
- Lian Li PC-Q25B Lan Cube
- ASUS P8H77-I Socket1155 2xDDR3 Max 16GB Mini-ITX Intel H77
- Intel Sockel 1155 Core i3 Processor i3-2120(3300MHz, L2/L3-Cache)
- 2x Corsair XMS3 PC-1333 RAM 4GB (CL9) DDR3-RAM
- up to 6x WD Cavier Green 2TB
- Sandisk Cruzer Fit Z33 16GB USB-Stick USB2.0
Now some general questions.
I heard that it is wiser to install FreeNAS onto a USB drive, instead of a partition. Is this true? If so, what is the reason behind this and is a USB 2.0 stick fast enough or should I rather get a USB 3.0? Currently, as you can see in my list, I got a Sandisk Cruzer with 16GB.
Furthermore, I read that instead of using RAID 5 or any software RAID system, I should rather go with ZFS filesystem. Are there any good threads as to why this is recommended and then, are there any good tutorials for setting this up?
Cheers,
NoT
Cheers,
NoT
